B16a motor swap problem into CX !!!!
Old Jul 9, 2004 | 06:45 PM
BpuTacoma's Avatar
Default B16a motor swap problem into CX !!!!
hey i have a weird problem with my swap.
93' CX
b16a3 with obd2 GSR harness with obd1 b16 ecu
swapped the motor in and wiring ect... i didn't have to cut any wires, everything plugged in.
problem, dash lights stay on with key removed. when i start the car, it runs fine, but when i remove the key it still runs.
i'm guessing it has something to do with the igniton or something, but i don't know.
any ideas ?
Old Jul 9, 2004 | 06:49 PM
Combustion Contraption's Avatar
i know this might sound stupid, but try hitting your hazard's when the key is out and still running. tell me what happens.
Old Jul 9, 2004 | 06:56 PM
BpuTacoma's Avatar
Default Re: (LsVtec92Hatch)
ok i tried that, and the backlights/ interior lights came on....
Old Jul 9, 2004 | 07:15 PM
hmm..... ive never heard of this when doing a swap, unless you messed with the wires inside the cabin. Did you touch anything in the cluster at all?
Old Jul 9, 2004 | 11:41 PM
BpuTacoma's Avatar
I didn't mess with any of the wires inside the cabin, except to put the b16 ecu in. I don't think it's a faulty cluster, maybe the 12+ ignition is getting power somehow with the key out....
i'm stumped
Old Jul 10, 2004 | 11:01 AM
BpuTacoma's Avatar
Default Re: (BpuTacoma)
bump....
Old Jul 11, 2004 | 12:27 AM
BpuTacoma's Avatar
bump for me who's stumped...
Old Jul 11, 2004 | 12:29 AM
Andres-eh2's Avatar
try a different ECU
Old Jul 11, 2004 | 12:47 AM
DOHCtorTHRUST's Avatar
Default Re: (Andres-eh2)
i bet it has something to do with the OBDII harness, i know its alot of work but if you can, swap it out for OBDI.
it's been done before and i know that the OBDII harness works, but its the only i see that could be faulty
Old Jul 11, 2004 | 12:56 AM
BpuTacoma's Avatar
Default Re: (DOHCtorTHRUST)
that's what i was thinking, the harness, but my friend has a 92' Si hatch, with a obd2 gsr harness with a LS/VTEC.
that's why i thought i could use it. i'mma see if i can find a obd1 harness.
or should i just ecu's to see ?
Old Jul 11, 2004 | 06:55 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCtorTHRUST &raquo;</TD></TR><TR><TD CLASS="quote">i bet it has something to do with the OBDII harness, i know its alot of work but if you can, swap it out for OBDI.
it's been done before and i know that the OBDII harness works, but its the only i see that could be faulty</TD></TR></TABLE>
No it's probably not the OBD2 engine harness. Unless that particular harness is damaged or something, there's no way the harness is causing the problem just because it's OBD2.
Sounds kind of like an ignition switch problem, or a grounding problem. Have you checked all of your grounds?
Old Jul 11, 2004 | 10:04 AM
BpuTacoma's Avatar
Default Re: (B18C5-EH2)
i thought i had all the grounds right
could a misgrounded wire cause this ? or a wire that isn't supposed to be grounded do this ?
Old Jul 11, 2004 | 04:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
Sounds kind of like an ignition switch problem, or a grounding problem. Have you checked all of your grounds?</TD></TR></TABLE>
i know that it works because of seeing your swap(pics). i know that it works, however it has something to do with the wiring, the cabin was not touch so that leaves the engine bay harness...
thats was just my .2 that i gave up top, if it was my car, it(the OBDII harness) would be the first place i will try to trouble shoot.
Old Jul 12, 2004 | 09:18 PM
BpuTacoma's Avatar
bump....
oh my turn signals don't work either...
Old Jul 12, 2004 | 11:25 PM
Civic92Turbo's Avatar
check the relays on the engine bay obd2 are different from obd1
Old Jul 13, 2004 | 06:06 AM
BpuTacoma's Avatar
Default Re: (Civic92Turbo)
would a bad relay cause the ignition switch to be in the *on* position all the time ?
Old Jul 13, 2004 | 08:15 AM
Evil_Wizard's Avatar
Does this thing have a alarm on it? Or have you recently pulled a alarm off of it?
Old Jul 13, 2004 | 08:40 AM
BpuTacoma's Avatar
Default Re: (Evil_Wizard)
i do'nt think there's an alarm system on it. i bought it used, but i'll look. any think i should look for ?
Old Jul 13, 2004 | 10:34 AM
Andres-eh2's Avatar
did you swap out the ECU yet?
Old Jul 13, 2004 | 11:23 AM
BpuTacoma's Avatar
i have a the b16 ecu in there. what ecu should i try ?
Old Jul 13, 2004 | 11:54 AM
OBD1Kenobe's Avatar
I assume by b16 ECU you mean the USDM P30 (Del Sol VTEC style y0!). You might try a P28 (5G ex/si). The maps are definately not great for a B16, but it should still run, and may pinpoint the ECU as the problem. I run my JDM B16 off a Kenji-chipped P28 and it is great.
Also, I believe the cx's "engine-bay-through-the-firewall-to-the-ECU" harness is not wired for VTEC (only 5G ex/si/vx are). If you wired this yourself, it may be possible that you used the wrong pinout on the ECU side. I dunno, just throwing out ideas...
I dug this up because I remembered reading about a similar problem a while back. Click here. I realize you said you didn't mess with anything in the cabin, but again, just another idea for you to consider.
BTW: I found that thread by searching on "hazard engine running" in archived content post bodies. Try some similar searches with some different keywords and you may be able to find a solution.
Sorry I couldn't be of more help. Good luck to you!
Old Jul 13, 2004 | 06:36 PM
H2B just chillin's Avatar
Default Re: (OBD1Kenobe)
ignition cylinder is worn the car is about 10 years old
Old Jul 13, 2004 | 09:13 PM
BpuTacoma's Avatar
Default Re: (20LvtecTURBOeg)
thanks for all the help, i've decided just to go buy a b16 harness, i guess something is cut or something on the gsr harness. oh well. that's what i get for trying to cut a corner.
Old Jul 14, 2004 | 06:35 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BpuTacoma &raquo;</TD></TR><TR><TD CLASS="quote">thanks for all the help, i've decided just to go buy a b16 harness, i guess something is cut or something on the gsr harness. oh well. that's what i get for trying to cut a corner. </TD></TR></TABLE>
You did NOT cut a corner!
You better save that engine harness in case you swap another one in and you still have the same problems.
People run the OBD2 engine harnesses all the time, myself included, with ZERO problems.
Again unless your specific harness is fucked you won't change anything by swapping harnesses.
Old Jul 14, 2004 | 08:09 AM
BpuTacoma's Avatar
yeah i'm saving the harness just incase. well i'll find out what it really is sooner or later.
