Fuel pressure on D16Z6???
What should the fuel pressure be on my engine. I have an adjustable B&M FPR, and it's set to 50psi. This is my setup. 90 civic hb with 95 sohc vtec, 88-91 si ecu, injectors, and distributor. Any help is really appreciated.
Thanks.
Thanks.
Those pressures are correct, IF you are using a SOHC VYEC ECU. He has a mini-me and the ECU doesn't boost the fuel curve when VTEC kicks in. Therefore you must run richer or high fuel pressure settings.
rasinhell
Jul 6, 2005 11:57 PM
