axle problems with b16a crx si
Old Jul 9, 2004 | 04:27 PM
tmihok's Avatar
Default axle problems with b16a crx si
I have a 1989 crx si with a b16a 1st gen. The problem is when the axle spins it is making the entire motor move up and down. I though the axle could be bad so I went out and got a 1991 integra ls axle. I put the new axle in and I am still having the same problem. Any ideas on what could be happening or what I need to do to fix this? Any help woulb be great.
Old Jul 9, 2004 | 05:40 PM
Rywire's Avatar
Default Re: axle problems with b16a crx si (tmihok)
Did you remove the dust ring, and seal? http://www.geocities.com/dropp...p.htm
Old Jul 9, 2004 | 05:48 PM
slowpokesi's Avatar
did you pull the dust seal check the swap guid in my sig
RanCRX
Jun 1, 2009 08:16 PM
1990 hf crx (Mick)
25
Apr 16, 2009 10:49 PM
c0d0r
Dec 21, 2007 09:33 PM
spooncivic01
Mar 16, 2005 06:07 PM
Dank26
Oct 29, 2001 10:23 PM
