g2 ecu, check engine light
Old Jul 9, 2004 | 03:37 PM
Chris_Bye's Avatar
Default g2 ecu, check engine light
i swapped in a 90 ecu in my 91 and the check engine light is on is this normal?
Old Jul 9, 2004 | 04:14 PM
Chris_Bye's Avatar
Default Re: g2 ecu, check engine light (91ntegra)
someone reply! i need to know if it is safe to drive!
Old Jul 9, 2004 | 07:45 PM
AzBlackTeg's Avatar
what are the codes that the ecu is throwing???
Old Jul 9, 2004 | 08:09 PM
ninjaturtle1023's Avatar
check the light on the ecu, and see what code its throwing
Old Jul 9, 2004 | 08:17 PM
AzBlackTeg's Avatar
Default Re: g2 ecu, check engine light (ninjaturtle1023)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninjaturtle1023 &raquo;</TD></TR><TR><TD CLASS="quote">check the light on the ecu, and see what code its throwing</TD></TR></TABLE>
booooo read above post
Old Jul 10, 2004 | 05:43 AM
Chris_Bye's Avatar
Default Re: g2 ecu, check engine light (AzBlackTeg)
the code of the ecu is 37820-PR4-AO2, and when i look at the ecu when the car is on it blinks once for about a second, then blinks two times in a row moderately fast. how am i supposed to get a code for that?
Old Jul 10, 2004 | 06:12 AM
Chris_Bye's Avatar
ok, i figured out some stuff myself , it is code 13, which is the atmospheric pressure sensor, located inside the ecu. From some research i did, it is recommended to replace the entire ecu from this problem . The thing is, i only need to use this computer for a couple days while my other computer is getting chipped an whatnot. Is it safe, or should i just wait?
Old Jul 10, 2004 | 08:13 AM
Jasper_db1's Avatar
The 90 and 91 Integra ECU's are different. 90's have an external PA sensor while the 91 has an internal one. That's why you're throwing a code.
Old Jul 10, 2004 | 12:10 PM
Chris_Bye's Avatar
Default Re: g2 ecu, check engine light (Jasper_db1)
so can i drive safely or not?
jfields06
Dec 27, 2008 06:42 AM
Lscivic1999
Jan 24, 2007 12:22 PM
frostt3ch
10
Jun 22, 2003 11:09 AM
BigMig
May 10, 2003 06:01 PM
RedRacerCivic
Dec 6, 2001 11:45 AM
