smaller tach and speedometer...
Old Jul 9, 2004 | 02:04 PM
madd's Avatar
Default smaller tach and speedometer...
i did a search on here and google to no avail. im looking for a smaller tach and speedometer so i can install more gauges into the stock cluster. id like to keep everything looking as much as stock as possible. only thing i have found are motorcycle gauges, but i don't think those will work. i hope im wrong...but does anyone know if they'll work or better yet if there is a gauge that is smaller than 3 1/2 inches for a honda (autometer has one that is 3 1/2...guess its same as stock...havn't measured). thanks!
Old Jul 9, 2004 | 02:20 PM
Mike813's Avatar
Default Re: smaller tach and speedometer... (madd)
if you want close to stock, either stick with stock or get a sir cluster... theyll all practically read the same anyway... just a higher rpm and mph if im not wrong?
Old Jul 9, 2004 | 03:33 PM
madd's Avatar
Default Re: smaller tach and speedometer... (Mike813)
well im wanting to add in a boost/oil pressure gauge, and maybe a fuel pressure gauge. i want the gauge cluster to look stock and flow with the car. i dont want an a-pillar or have gauges sticking out of every crevace of my interrior. what *i* really want to do is modify the cluster to include all the gauges.
Old Jul 9, 2004 | 04:02 PM
v4lu3s's Avatar
RTFM
good luck on that. the whole cluster is designed as a unit, to be able to modify it and not lose fucntionality of it could be quite the pain in the ***.
Old Jul 9, 2004 | 04:12 PM
madd's Avatar
Default Re: (v4lu3s)
indeed, but i have time! im the proud new owner of a second f22b2 so ill be spending the next few weeks pulling it apart and cleaning. ive decided on pistons and rods, but i may just go ahead and do a resleeve so as not to have to pull it apart again (also depending on the condition of the cylinders when i pull the head tomorrow). aiming for a fully built engine by spring or late winter being optimistic.
Old Jul 9, 2004 | 04:30 PM
Mike813's Avatar
Default Re: (madd)
why dont ya take out the heater ***** and use that as a pod... or use fiberglass and fabricate yourself a pod.
Old Jul 9, 2004 | 05:34 PM
Riceburner247's Avatar
Default Re: (Mike813)
You could get a spare cluster, then fab in a complete new setup using autometer gauges. Just a thought.
.bagged's Avatar
Default Re: (riceburner247)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner247 &raquo;</TD></TR><TR><TD CLASS="quote">You could get a spare cluster, then fab in a complete new setup using autometer gauges. Just a thought.</TD></TR></TABLE>
hmm..rings a bell
Old Jul 9, 2004 | 05:39 PM
Default Re: (bagged93accord)
It just comes natural, what can I say.
Old Jul 9, 2004 | 06:52 PM
madd's Avatar
i dont really want to make a pod...or take out my heater *****. im a bastard..i know.
riceburner:
thats what i plan on doing....atleast i think we're on the same page. i wanted to buy a spare cluster and create a new...."background" (whatever you call it) and position ALL of my needed gauges in the stock cluster. the only problem is finding a small enough tach/speedometer. i would more or less reposition everything since i would be going through the trouble, but if i can't find a tach/speed that will work then its pointless. thats why i was hoping there would be a way to rig up a motorcycle tach/speedometer, but i dont see that happening....so i guess ill have to think about doing it some other way.
Old Jul 9, 2004 | 11:36 PM
.bagged's Avatar
Default Re: (madd)
I did it to my cluster with all auto meter. spedo, tach, fuel, water temp. plenty of room. 3" tach and speedo 1.75" fuel and water.
back ground made out of 18 gauge sheet metal.
Old Jul 9, 2004 | 11:42 PM
iam7head's Avatar
i know they see those boost guage size guage for speedo and rpm in digital display
Barry116
Feb 18, 2012 07:21 PM
1sick4g63
Aug 20, 2008 10:51 AM
xkuco
11
Oct 26, 2006 01:52 PM
hondahustle
12
Jun 15, 2006 01:09 AM
