Going through starters every week. Help Me please.
Old Jul 9, 2004 | 12:19 PM
ThaSpitefulWun's Avatar
Default Going through starters every week. Help Me please.
I have been going through starters like crazy. One works for like a week and then nothing. If I let the car sit for a few days, it will work again without me actually doing anything to the car, but it will only work for a short time.
When i say the starter goes, i obviously mean it doesn't work anymore. No turning over at all. The gear itself doesn't even pop out of the starter itself to spin the flywheel.
Both Starter bolts are in, so i know it is properly grounded.
The thing I really don't understand is that sometimes if i turn the key and nothing happens, I can hold it there for a second and it will turn over. Car has no problem when I try to pop start it, and runs fine when it is running.
I really am pretty clueless as to why this is happening. I am perfectly willing to accept the fact that i am just getting really unlucky with the rebuilt starters, but the symtoms themselves don't seem right. Either the starter goes or it doesn't, there is no in between in my experience.
Let me know if you can help, any suggestions will do... thanks!
Old Jul 9, 2004 | 12:44 PM
Default Re: Going through starters every week. Help Me please. (ThaSpitefulWun)
So I figured i would take a look at my Main relay, got under my dash moved some wires around, and for the heck of it tried to start my car. It didn't start, but now the gear is popping out out of the starter itself, where as before nothing would happen...
Another Dead Starter, this will make 4 in less than two weeks!
Old Jul 9, 2004 | 12:48 PM
98spydert's Avatar
Are you testing them out of the car? Might be a long shot but it sound like a bad battery, bad battery connection, or the ground. Just a thought...
Old Jul 9, 2004 | 01:06 PM
Default Re: (98spydert)
Each time minus the starter before this one and the one i have now i have been bench testing before i return them... but get this...
I came back inside flipping out, typed above message than sat down and watched the end of Rodney Dangerfield's Back To School, then went back outside to play with the car again... this time it starts!
What the?
Old Jul 9, 2004 | 01:15 PM
98spydert's Avatar
****, somebody call an exorcist!
Old Jul 9, 2004 | 01:16 PM
Keebler's Avatar
Default Re: (ThaSpitefulWun)
Battery or connection... Double check all your connections and make sure you have a good battery w/ plenty of amps
Old Jul 9, 2004 | 01:51 PM
onepoint6i's Avatar
when your car doesnt want to crank over,
-leave the key on the ON position,
-MAKE SURE ITS IN NUETRAL
-pop the hood
-get a piece of wire (speaker wire)whatever, and jump the starter from the St terminal to the positive right next to it.
it shouldnt crank over and start if the starter is bad.
if it does start then your problem lies in the neutral safety switch or the actual ignition switch
Old Jul 9, 2004 | 02:04 PM
Default Re: (1.6i)
thank you for an effective way to check if my starter is bad. apparently the starter is good since it has started the car about ten times over the past hour... i redid battery connections but won't be able to check amps til i can borrow a meter... if battery is good i will attempt ignition switch next... easy job to replace ignition switch?
Old Jul 9, 2004 | 02:15 PM
onepoint6i's Avatar
i have the same problem with my 90 crx, just been too lazy to diagnose the neutral switch and the ignition. i just pop the hood and jump it.
the ignition is pretty easy to swap out though.
Old Jul 9, 2004 | 07:11 PM
Default Re: (1.6i)
thanks for the info
Old Jul 9, 2004 | 11:21 PM
Keebler's Avatar
Hope it works out for you, keep us updated
Old Sep 5, 2004 | 02:05 PM
Default Re: (Keebler)
is there a tutorial or something that i can get a link too about how to change out ignition switch and the neutral safety switch?
Old Sep 5, 2004 | 02:11 PM
ok i found out how to change out the ignition switch, but im still lost on the neutral switch?
Old Sep 14, 2004 | 07:38 AM
can i get a little hand in here?
da_33
Dec 1, 2007 12:20 PM
Rooftop voter
May 7, 2007 02:28 PM
projectPSI
Mar 18, 2005 02:54 PM
Civicboy
Mar 15, 2004 06:02 PM
gliaw
Nov 21, 2002 02:53 PM
