Mount Question: read something I want verified
Old Nov 21, 2001 | 08:02 AM
DragII's Avatar
25 Year Member
Default Mount Question: read something I want verified
I'm putting a B16 from a Del Sol into my 6th gen coupe.
on Http://www.hybrid.honda-perf.org
he states that on the lower front mounts you should use the civic rubber, and stud.
is this REALLY necissarry? I'm ok w/ using the civic rubber....but the Studs have GOT to be the same....I don't want to change out the studs.
Old Nov 21, 2001 | 11:20 AM
DragII's Avatar
25 Year Member
Default Re: Mount Question: read something I want verified (DragIIcivic)
c'mon....I know someone did this swap themselves...Which hardware did you use??
Old Nov 21, 2001 | 12:26 PM
fowler!'s Avatar
you don't need to change the studs. Only if you strip them or something.
*edit* ..you're talking about the drivers side? or the passenger side?
[Modified by fowler, 9:27 PM 11/21/2001]
Old Nov 21, 2001 | 12:27 PM
DragII's Avatar
25 Year Member
Default Re: Mount Question: read something I want verified (fowler)
That's what I thought.
Both should be the same, no?
jonstaub2011
Nov 30, 2010 07:14 PM
black'n'white
Jan 12, 2008 10:34 AM
lsdelslow
May 27, 2006 01:36 PM
chung
Jan 15, 2003 07:11 PM
