Need Help swapped 4 door ex with b16 from 00 si check engine light on HELP!!!
i need some help please. ive got a 96 civic sedan ex. i swapped out the stock d16y8 sohc vtec engine out for a 2000 si b16 dohc engine. the car currently is running okay but my check engine light is on and when i put a scanner on the data link connector it read out of range or error. engine, tranny, engine harness and ecu are all from si. the dash harness is stock from the ex. when i did the swap my cooling fan and speed o did not work but all i had to do was swap the pin locations. please if anyone can help me in any way such as what wires to connect or even point me in some direction i would gladly appreciate it. thanks so much.
EJ8_Enthusiast
25
Aug 26, 2008 09:57 AM
jaynmeli
Jan 25, 2008 06:00 PM
JD[ehem]
Apr 20, 2005 07:15 PM
