vin number on motor question
Old Jul 9, 2004 | 08:14 AM
Guru Designs's Avatar
* B A N N E D *
Default vin number on motor question
i recently bought a 94 gsr. my crank shaft went and i started to take that motor apart and i started noticing that most of the parts on this car arent from a stock gsr. ie head is a type r head (pr3-3) flywheel is a p30. so im scared that this motor might be stolen so how can i check if the motor is actually legit. thanks for your help in advanced
Old Jul 9, 2004 | 09:46 AM
greaseball's Avatar
Default Re: vin number on motor question (tobe2be)
VIN# should be right on the front of the motor. it's in plain sight. if you can't find the VIN on the block, then there's a chance it was removed. at any rate, it should be on the front of the block. good luck.
Old Jul 9, 2004 | 10:03 AM
JimBlake's Avatar
Default Re: vin number on motor question (greaseball)
They didn't start putting the VIN on engines until about '97 or ?? What's on the front of the block is the engine serial #.
If the block is really from a '94 GSR the first digit of the serial # should be 1. Like B18C1 on the first line, & 1nnnnnnn on the second line.
edit:
I bet the cops or DMV only keep records on stolen VINs, not block serial#s. Call your friendly local police station... I bet they'll want to come over & look at it.
Maybe Honda themselves keep records of which engine was installed in which vehicle, but I've never heard of anyone actually getting that information.
Modified by JimBlake at 3:47 PM 7/9/2004
Old Jul 9, 2004 | 11:05 AM
* B A N N E D *
ok there is a number under the b18c1 but where can i type this number to find out if its stolen or not.
Old Jul 9, 2004 | 11:26 AM
gt35r's Avatar
Default Re: (tobe2be)
Cant you do it on car fax, or the dmv?
Old Jul 9, 2004 | 12:08 PM
Kendall's Avatar
Unless the actual VIN on any part of the car is from a car that's reported stolen, then there's no way to tell.
eggsi619
Jun 15, 2009 07:33 PM
underb00steg6
Apr 22, 2004 02:50 PM
GSRHATCH187
Oct 8, 2003 03:52 PM
253EK
Feb 18, 2003 06:07 PM
blackANESE
Feb 21, 2002 09:08 AM
