Weird clicking feeling in my clutch pedal
Old Jul 9, 2004 | 07:55 AM
6MTV6's Avatar
Default Weird clicking feeling in my clutch pedal
Just like it says guys, what's going on? It only happens when I decellerate. It's a weird feeling for sure...
Old Jul 9, 2004 | 10:34 AM
6MTV6's Avatar
Default Re: Weird clicking feeling in my clutch pedal (Bishop4G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bishop4G &raquo;</TD></TR><TR><TD CLASS="quote">Just like it says guys, what's going on? It only happens when I decellerate. It's a weird feeling for sure...</TD></TR></TABLE>
BUMP
P.S. It doesn't feel anything like CV axles.
Old Jul 12, 2004 | 07:21 AM
6MTV6's Avatar
Bump.
C'mon people. This clicking feeling is weird, and I know it can't be a good thing.
Any ideas.
Old Jul 12, 2004 | 07:42 AM
Keebler's Avatar
Maybe your throw-out bearing, or fork. What kind of tranny? Hydro or cable?
Old Jul 12, 2004 | 08:15 AM
icon_race_eg's Avatar
mine does it too,
i dont think it is anything bad. its done it ever since last winter. no problems since then and it grips just fine and dandy.
Old Jul 12, 2004 | 09:09 AM
6MTV6's Avatar
Default Re: Weird clicking feeling in my clutch pedal (Keebler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keebler &raquo;</TD></TR><TR><TD CLASS="quote">Maybe your throw-out bearing, or fork. What kind of tranny? Hydro or cable?</TD></TR></TABLE>
I have a Y1 cable tranny w/ LSD. It started doing it after I ran against this guys Z29R. About a week or so now...
Old Jul 12, 2004 | 10:16 AM
Keebler's Avatar
Only feel the click when you let off the gas, like from a full throttle, to letting off you then feel the click?
Is it audible?
Old Jul 12, 2004 | 12:12 PM
6MTV6's Avatar
Yeah I can hear it. It happens when I shift into neutral from any kind of driving, not just running hard.
Old Jul 12, 2004 | 04:51 PM
sporkcrx's Avatar
Yea I've always had that too. I can't really hear it, but I can feel it.
Old Jul 12, 2004 | 05:02 PM
520_Motorsports's Avatar
check the bushings in your shift linkage and your roll pin. also check tightness of everything. could possibly be loose.
Old Jul 13, 2004 | 06:50 AM
6MTV6's Avatar
Default Re: Weird clicking feeling in my clutch pedal (fastlx-i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastlx-i &raquo;</TD></TR><TR><TD CLASS="quote">check the bushings in your shift linkage and your roll pin. also check tightness of everything. could possibly be loose.</TD></TR></TABLE>
I've got to pull my tranny in a couple weeks so I can put new synchros in it and put on an ITR flywheel, I'll do it then.
Old Jul 17, 2004 | 08:10 AM
90tegz's Avatar
it happens to me too just started a month ago but it doesnt seem like theres ne problems with it
Old Jul 19, 2004 | 06:39 AM
6MTV6's Avatar
Default Re: Weird clicking feeling in my clutch pedal (90tegz)
Well I tried pulling my CV's this weekend. First time on this honda about the 10th time I've done it though. Got the driver's side out. Not really any problems there. When I got to the passenger side, it just got shitty. I can't get the CV out of the transmission. I went to Sears and bought a prybar set. I had a 17 inch and 2 foot prybar on it, and couldn't bust it out.
On a sidenote, it got so bad on the way home, I thought my tranny was going to lock up. I cut the boots on my CV's the were perfect looking inside. I'm dropping the tranny today. I'm just going to buy a new one, then fix this one for my CRX.
Old Jul 19, 2004 | 07:11 AM
emwavey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bishop4G &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I can hear it. It happens when I shift into neutral from any kind of driving, not just running hard.</TD></TR></TABLE>
I had something like this in a Stock Si Tranny... it was the throw-out bearing (sp?)
Old Jul 19, 2004 | 07:16 AM
6MTV6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bishop4G &raquo;</TD></TR><TR><TD CLASS="quote">I had a 17 inch and 2 foot prybar on it, and couldn't bust it out.
On a sidenote, it got so bad on the way home, I thought my tranny was going to lock up. I cut the boots on my CV's the were perfect looking inside. I'm dropping the tranny today. I'm just going to buy a new one, then fix this one for my CRX. </TD></TR></TABLE>
I've never had a CV I couldn't get out w/ a long screwdriver. This sucks.
Old Jul 19, 2004 | 07:49 AM
Keebler's Avatar
At times the little rings on the end of the axles can spread, causing the axles to stick in the tranny.
Ive had a couple where I thought I was going to break the tranny housing getting it out.
Can you see the axle from the other side? You said you got the driver off right? Well, can you peer in the hole and see the other axle? Sometimes there is a pin in the way, but try to get a clear shot with a punch, or see if the ring is bound.
Old Jul 19, 2004 | 08:12 AM
6MTV6's Avatar
I figured that's what the problem is. I ended up breaking my seal. I think. It started leaking fluid while trying to break it loose. I'd have to pull my intermediate shaft to see into the tranny. I'll check when I pull the tranny tonight. I figured 2 200+ lb guys w/ prybars would be stronger than the spring clip.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keebler &raquo;</TD></TR><TR><TD CLASS="quote">At times the little rings on the end of the axles can spread, causing the axles to stick in the tranny.
Can you see the axle from the other side? You said you got the driver off right? Well, can you peer in the hole and see the other axle? Sometimes there is a pin in the way, but try to get a clear shot with a punch, or see if the ring is bound.</TD></TR></TABLE>
Thanks man. I'll do that.
Old Jul 19, 2004 | 08:47 AM
6MTV6's Avatar
Talked to the guy at Hasport, he said the locking is common w/ LSD trannies. He gave me the same advice you did.
Old Jul 19, 2004 | 09:47 AM
Keebler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bishop4G &raquo;</TD></TR><TR><TD CLASS="quote">Talked to the guy at Hasport, he said the locking is common w/ LSD trannies. He gave me the same advice you did.</TD></TR></TABLE>
Excellent, glad I could help man. Guess I need to get a job wrenching again :D
Let us know how it goes
cbmprelude
10
Oct 7, 2006 03:12 PM
M2B4
Apr 5, 2006 08:02 PM
SandFireTypeR
11
Oct 28, 2004 12:24 PM
NOahFATCHICS
Oct 20, 2004 04:20 AM
JFG Kevin
May 7, 2004 09:31 PM
