Broken JDM fog casing
On my JDM conversion, the yellow plastic casing around the fog lights broke and are now rolling around inside the head light assembly. I have no clue how this happened or why and I really didn't want to spend the money on a new set of lights.
I was thinking I will open them (need to be cleaned anyways) and try to glue it back together. Will this hold? I'm thinking they probably make a clear plastic expoxy that would work. Any suggestions?
I bought some Devcon 5 min clear epoxy, I don't know if this will stick to the plastic, but it isn't flamible and holds from -40 to +200 F, although in MN it can get below -40.........
ok, i have the same question, except im wondering if anyone has any input to how i can get the broken casing out of the headlight housing, without heat gunning the lense off. heres the pic!
