help! where does this hose go?
Old Jul 9, 2004 | 12:08 AM
DC2point0's Avatar
Default help! where does this hose go?
I was cleanning up my engine bay today and went across this hose can someone tell me where its supposed to go?
Old Jul 9, 2004 | 01:12 AM
DC2point0's Avatar
Default Re: help! where does this hose go? (jdm_styl3)
anyone?
Old Jul 9, 2004 | 04:13 AM
JimBlake's Avatar
Maybe if we could see the other end of that hose, & if you told us what year GSR that is...
Old Jul 9, 2004 | 04:45 AM
Slimm-rw-'s Avatar
I'm a Jackass
Default Re: help! where does this hose go? (JimBlake)
you need to get a hanes manual, then find the sections on throttlebodies. then learn some more abuot how they work. That's the only way to know not just where its supposed to go, but why.....
Old Jul 9, 2004 | 08:51 AM
IN VTEC's Avatar
On top of the throttle body for the EVAP purge inlet? If it's like a 6mm hose, then that's probably what it is.
Old Jul 9, 2004 | 09:30 AM
JimBlake's Avatar
Default Re: help! where does this hose go? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">On top of the throttle body for the EVAP purge inlet? If it's like a 6mm hose, then that's probably what it is.</TD></TR></TABLE>I think the EVAP purge line is there in the top-right, like about 1 o'clock in the picture.
That thing's bigger & it's got reinforcing cords. It looks like a fuel or coolant hose.
Old Jul 9, 2004 | 09:48 AM
EdoMoto's Avatar
looks like its allready attached to the throttle body on one side. So the side you are holding goes in to the EVAP canister.
Old Jul 9, 2004 | 10:40 AM
19da90's Avatar
Default Re: help! where does this hose go? (ITAIntegraLS)
water pump maybe
Old Jul 9, 2004 | 10:47 AM
mEr's Avatar
mEr
Default Re: help! where does this hose go? (19da90)
looks like a coolant line..
Old Jul 9, 2004 | 10:48 AM
19da90's Avatar
Default Re: help! where does this hose go? (R...)
i was thinking the bigger 1 was the coolint the water pump was the smaller one maybe i wrong thou
Old Jul 9, 2004 | 01:16 PM
Grease Monkey's Avatar
get some better pics please so we know where the other lines go.
Old Jul 9, 2004 | 01:51 PM
IN VTEC's Avatar
Curse these squinty eyes of mine. Since it's obviously not the EVAP purge, then I'll put $20 on the TB to upper radiator hose housing coolant line and $10 on the PCV atmospheric line from the intake to the valve cover.
Old Jul 9, 2004 | 02:55 PM
IN VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITAIntegraLS &raquo;</TD></TR><TR><TD CLASS="quote">looks like its allready attached to the throttle body on one side. So the side you are holding goes in to the EVAP canister.</TD></TR></TABLE>
Totally missed that. I'll drop a dime on that bet.
Old Jul 12, 2004 | 03:48 AM
JimBlake's Avatar
OK I looked at mine yesterday... If that's the hose that's attached to the throttle body, immediately above that blue coupling, then it goes to the EVAP canister.
There's 3 hoses at the EVAP canister. One by itself is the vapor line coming from the gas tank. Then there's a valve with 2 hoses. The smaller one is on top, that's the non-reinforced vacuum hose you can see way up high, about 1-o'clock in the picture, attached to a solenoid valve. The bigger one, closer to the EVAP canister, goes to the throttle body right above the bore.
But I'm still not sure whether that's the same hose that curves around out of view on the left side of the picture, & goes to the TB. If it's not, then we need to see the other end of the hose he's holding.
PSI Racing
10
Jan 27, 2020 04:28 PM
Wyatt87
Aug 15, 2012 12:48 PM
EF8IGHT
Nov 8, 2005 07:53 AM
HaUTSaauce
Sep 27, 2003 07:01 PM
DeDonDeRosa
Dec 11, 2002 08:24 AM
