CRX Del Sol seats and Water leak
Old Jul 9, 2004 | 12:02 AM
sublimecrx's Avatar
Default CRX Del Sol seats and Water leak
I need some help on how to install del sol seats into my crx. tried changing out the rails, but they are not even similar. please help.
I also have a water leak in the rear and kinda figured out where its comming from.
I stripped out the interior and saw that water was making its way in through the area above the taillights. It does not leak from the hatch (new seal), or from the tail lights, but from some little black triangle looking things in the inside of the hatch assembly. i did notice that my tail lights were filling with water though, what do i do?
Another problem: my front pass wheel is shifted to the left and towards the inside of the car. i have new tokiko blues and new springs, what is this, plus, my drivers side is lower than my pass. side.
PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
Old Jul 9, 2004 | 12:09 AM
Hybridcrx469's Avatar
Default Re: CRX Del Sol seats and Water leak (sublimecrx)
Well your not alone . EVERYONE who i know has the same leak probelm. do a little searching and you'll find all kinds of topics. But since i just posted one not to long ago i have a link. Its got about two pages of info. I will say check your rear squirter!!! 95% that is the problem
https://honda-tech.com/zerothread?id=361999
Old Jul 9, 2004 | 12:14 AM
sublimecrx's Avatar
Default Re: CRX Del Sol seats and Water leak (Hybridcrx469)
MY LEAK DOES NOT COME FROM THE HATCH, OR THE STRUTS, IT COMES FROM THE CHASSIS ABOVE THE TAIL LIGHTS
Old Jul 9, 2004 | 12:24 AM
sublimecrx's Avatar
AGAIN IT COMES FROM ABOVE THE TAIL LIGHTS, NEW TAIL LIGHT SEALS, NOT THOUGH TAIL LIGHT OPENINGS
Old Jul 9, 2004 | 12:35 AM
Exempt's Avatar
Only way to tell is get someone with a hose and sit in there and watch... Thats how I found my leak... Mine was the infamous washer nozzle... Slapped some clear silicone on it, and its all better...
Old Jul 9, 2004 | 12:45 AM
Rostr02's Avatar
i put teg seats in my crx. I took the teg top part of the seat and bolted it to the crx bottom with no modification. My guess is to try that. I t has a slight gangster lean but it dont look too bad
Old Jul 9, 2004 | 12:46 AM
Default Re: CRX Del Sol seats and Water leak (Exempt)
Oh no, you just mentioned the washer nozzle leak again. Now this guy is really going to be pi$$ed off! lol
Old Jul 9, 2004 | 01:15 AM
KaoticSnow's Avatar
cehck the drains for the sunroof?
Old Jul 9, 2004 | 03:30 AM
crx_88_si's Avatar
drill two small holes in the bottom of each tail light housing.
Old Jul 9, 2004 | 09:04 AM
KaoticSnow's Avatar
you could do that but If it was me I'd rather find where the watter is coming form and fix it.
SuppDude1
Apr 4, 2021 08:27 PM
Deesoll
Jan 21, 2014 08:01 AM
Mike Polinder
Jan 13, 2011 01:23 PM
CrxDin
Nov 15, 2009 01:48 PM
hermanssol
Jan 14, 2008 09:49 PM
