B16A1 / EF-8 Stock Airbox, Etc. ???
Old Jul 8, 2004 | 07:13 PM
tweakit's Avatar
Default JDM freaks bid while you can, bumper pole for the EFs! (not my auction)
thread edited because i hit my post limit!
this thing is going to go for a pretty penny, i just know it.
http://cgi.ebay.com/ebaymotors...42611
--------------------------------EF-8 Airbox thread begins here-----------------------
I'm going for a totally stock look underneath the hood when I'm done with my B16 swap. I'm wondering if using the stock airbox from a 90 Si would work. I would really like to get ahold of the EF-8 airbox assembly, but not sure if it would bolt on correctly.
Does anyone have any tips on what to do with the stock pieces, or if the EF-8 pieces will work? (If the EF-8 pieces DO work, then where can I get them?)
Thank you very much, and yes... I already did a search for this topic under numerous terms!
Modified by tweakit at 11:14 PM 7/12/2004
Old Jul 8, 2004 | 07:48 PM
crxguy05sir's Avatar
Default Re: B16A1 / EF-8 Stock Airbox, Etc. ??? (tweakit)
hmo has the EF8 ones
Old Jul 8, 2004 | 07:51 PM
temp's Avatar
Default Re: B16A1 / EF-8 Stock Airbox, Etc. ??? (crxguy05sir)
i have a stock JDM B16a airbox i could sell yah
Old Jul 9, 2004 | 05:23 PM
tweakit's Avatar
Default Re: B16A1 / EF-8 Stock Airbox, Etc. ??? (temp)
Bump, and I ordered one with my b16 from hmotorsonline. for 50 bucks. Now im just hoping it will bolt up correctly (i know it will, but the fit is what im hoping works) After all, the engine isn't in the exact same place as the JDM SiR.
Anyone ever tried this?
Also, this is off topic, but anyone ever get "scolded" by authorities for having a Kmph speedo? lol just curious.
Thanks guys.
Old Jul 9, 2004 | 05:31 PM
Rywire's Avatar
I have the crx air box with xsi intake arm. It looks similar, but ya, the sir stuff will fit just fine. Ive seen one in person. Ryan
Old Jul 12, 2004 | 05:49 PM
tweakit's Avatar
Default Re: B16A1 / EF-8 Stock Airbox, Etc. ??? (droppedcrxsi)
Bump for another question about the airbox. Will the regular filters for the CR-X Si's work for the SiR airbox? I have a K&N I would like to continue using. Not sure if the box was made bigger for more CFM or not. Thanks!
Old Jul 12, 2004 | 05:58 PM
fourthgenhatchB17's Avatar
The SiR air box is bigger. U will have to order a new K&N for it. I ordered mine online. I dont know if the USDM passenger side headlight will interfere with the air box tho, since the air box is longer. I have the SiR headlights and my EF9 stuff fit perfect.
Old Jul 12, 2004 | 06:29 PM
BlueShadow's Avatar
Default Re: B16A1 / EF-8 Stock Airbox, Etc. ??? (fourthgenhatchB17)
Say does anyone know if a EF with a swapped B16/B18C5/B18C1 and S2 IM will work with a 99-00 Civic Si intake arm?
Old Jul 12, 2004 | 07:43 PM
tweakit's Avatar
Where did you find the air filter, and what part number or what model is it for? I won't be ordering one until im sure the actual box will fit in there with the USDM front end. But its good to have handy just in case.
Thanks, Scott.
Old Jul 12, 2004 | 09:24 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweakit &raquo;</TD></TR><TR><TD CLASS="quote">Where did you find the air filter, and what part number or what model is it for? I won't be ordering one until im sure the actual box will fit in there with the USDM front end. But its good to have handy just in case.
Thanks, Scott.</TD></TR></TABLE>
the k&n site lists the part number.....neato isnt it?
amsti06
Jan 15, 2014 06:26 PM
jdmkid8383
May 15, 2007 08:01 PM
stealthteg
Apr 24, 2002 02:55 PM
