d16y7 and d16z6 parts same?
From: 9/11/01 WTC Never Forget, United States Of America
As far as the engine pieces go are d16y7 and d16z6 compatible?
ex: water pump
timing belt
tension pulley
part #'s are different
ex: water pump
timing belt
tension pulley
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.RED’89 »</TD></TR><TR><TD CLASS="quote">As far as the engine pieces go are d16y7 and d16z6 compatible?
ex: water pump
timing belt
tension pulley
Somebody anybody
ex: water pump
timing belt
tension pulley
Somebody anybody
My experience is with a Z6 and a Y8.
Most parts did NOT interchange. I did re-use a z6 tensioner on the y8.
Water pump gear is different.
Covers are different, pulley is different, crank gear is different...
Lots of money to switch block generations. Stay with the block you have accessories for. I spent $200 getting all new parts for a y8 when I already had all Z6 stuff on hand
If you need z6 stuff, I have a ton lying around, including 2 blocks...
Wilmer787
Jan 15, 2012 10:00 AM
Wilmer787
Jan 15, 2012 03:51 AM
CivicxTree754
Nov 15, 2011 01:23 AM
Eg Smurf
Jul 23, 2004 06:57 PM
belt, compatable, compatiable, crank, d16y7, d16z6, d16z6d16y7, fits, gear, interchange, parts, pump, timing, transmission, water
