stock or open header
Old Jul 8, 2004 | 06:23 PM
hondanamics's Avatar
Default stock or open header
i have a 91 accord my stock exhaust is falln apart just wondern what kinda performance i will c if i run open header. open vs. full stock exhaust. also what kinda resonator should i use to keep the sound down somthing like a glass pack
Old Jul 8, 2004 | 06:25 PM
propwdialogue's Avatar
Default Re: stock or open header (hondanamics)
your sound is going to be ridiculously loud and you will lose low-end tq. not to mention the pollutants you will be spewing into the air running a test pipe. unless you are going full-bore track (including FI) you should probably do either a cat-back or an OE replacement.
Old Jul 8, 2004 | 07:06 PM
PowerUser's Avatar
A open header sounds really bad man (in a bad way to be 100% clear ). I've heard it a couple times from other cars on the road. it's louder then any Apexi N1 @ WOT.
what kind of sound are you looking for with a new exaust? nice and quiet? quiet when cruseing around and looud when you get on the gas?
Old Jul 8, 2004 | 08:17 PM
Riceburner247's Avatar
Default Re: stock or open header (PowerUser)
If you run open header too long, you risk sucking a valve, not to mention **** a lot of sleeping people off.
DC2R_GUY
Oct 2, 2007 04:45 PM
Brown-tec
May 18, 2006 07:54 PM
00CivicSleeper
Mar 31, 2005 09:59 AM
JdMjOhNyO
Mar 15, 2005 11:56 AM
