jdm d15 vtec dizzy problems
Old Jul 8, 2004 | 05:57 PM
illusive's Avatar
Default jdm d15 vtec dizzy problems
Ok I searched and didnt come up with much so my question is we are doing a swap in my dads 4th gen(89 civic hb DX) we are swapping the stock dpfi dx motor for a jdm d15 vtec motor. We tried fitting on the d15b2(stock dx) dizzy on the new jdm d15 vtec fits in but none of the holes line up. What can I do? Since its a 92-95 obd 1 motor the plugs would be different if we purchased the dizzy that went with the motor correct? Is there another dizzy that will work thats obd 0. Or am I **** out of luck and have to convert to obd 1. If you have any input that would be great.
Old Jul 8, 2004 | 06:13 PM
MENACE's Avatar
Default Re: jdm d15 vtec dizzy problems (illusive)
If you want to run it Obd0 You must use the SI Distributor. Only the top hole Kinda lines up. Youll need to Widen it out and have that 1 bolt hold it in. Or cut of the front leg and and make a new leg for the front mount. Curently i Just have the one bolt holding it in.
Old Jul 8, 2004 | 06:51 PM
illusive's Avatar
Default Re: jdm d15 vtec dizzy problems (MENACE)
thanks for the info, anything else I will run into that I should know about? Any more help?
turboblack2door
Apr 1, 2009 07:09 PM
efjones9
Feb 20, 2009 08:37 AM
aXhatch
Feb 3, 2006 08:31 PM
B18C5-EH2
Mar 21, 2003 12:06 PM
Timmayeg
Jan 15, 2003 12:23 PM
