Oil Attention Light
Old Jul 8, 2004 | 04:43 PM
livelife46290's Avatar
Default Oil Attention Light
Whenever I start my car either after it has been running for a little while or its cold the oil light always comes on! I think its a malfunction in the sensor because i check the oil every week and theres always plenty in it, does anyone have any remedys or suggestions on what to do, all i want to to is not see a flashing oil light but still have the circuit in place so i can be alerted if there is not enough oil!
Old Jul 8, 2004 | 07:32 PM
accordnut's Avatar
Default Re: Oil Attention Light (livelife46290)
The light is for oil pressure. I would recommend attaching a manual oil pressure gauge to where the oil pressure sensor is now a confirm you have oil pressure within spec. If oil pressure is ok the replace the sensor.
Old Jul 8, 2004 | 07:35 PM
The_Todd's Avatar
Farts in the shower
oem oil light=when you are about empty on oil
Its mainly for looks and doesn't really serve much of a purpose . IMO a aftermarket oil pressure gauge will do more than ok
Colorado
Old Jul 9, 2004 | 08:30 PM
Where can I pick up an aftermarket oil pressure gauge and what do i need to mount it and so on and so forth. Do you know where the sensor is located because I cant find it I even have a chiltons and i still cant find it.
Old Jul 9, 2004 | 08:47 PM
91AccordSE's Avatar
Default Re: (livelife46290)
The sensor is right below your intake manifold. It is directly above your oil filter.
I would buy a T-fitting, and screw the aftermarket gauge sender in one port, and the OE sender in the other, but I seem to remember someone saying that this was not a good idea on these cars for some reason. I can't remember why. Maybe whoever wrote that will offer another suggestion.
As was mentioned above, the light comes on when your oil pressure is low, so be careful driving around when the light is on. You might end up burning up a bearing if the pressure really is low.
Old Jul 14, 2004 | 05:15 AM
I dont think that its too low, the car isnt burning any oil or anything like that, i talked to one of my friends and he suggested to get the oil pump looked at, so thats the next step for now.
MyUsernameName
Jun 15, 2017 02:06 PM
curtie94
May 26, 2011 07:35 AM
eric416
Oct 9, 2008 04:03 PM
toyH22
May 31, 2006 02:05 PM
BACKintheDA
Jul 12, 2005 01:05 PM
