Bottomed out my car, smacked header. What to check for?
Old Nov 20, 2001 | 11:05 PM
onyx00's Avatar
Default Bottomed out my car, smacked header. What to check for?
Okay, I hit a bad dip about 30-40 Mph and hte car bottomed out and smacked the header. Heat shield on header seemed to protect it (it's a JDM 4-1), but what else do I need to check in a situation like this? Suspension? Bolts holding the header on the engine?
Thanks!
Old Nov 21, 2001 | 07:03 AM
onyx00's Avatar
Default Re: Bottomed out my car, smacked header. What to check for? (onyx00)
ttt
Old Nov 21, 2001 | 07:07 AM
immortal's Avatar
Banned
make sure your oil pan is ok.
Old Nov 21, 2001 | 08:48 AM
05 600RR's Avatar
Check your struts to make sure they are ok.
Old Nov 21, 2001 | 08:52 AM
Big Phat R's Avatar
I did that with my Mugen 4-1 header - basically killing it. 2 of the primaries flattened.
The JDM header is the same material (not stainless I think)- and very likely your motor mounts took the brunt of the impact. Still you should check the header mounting bolts and the mounting brackets and the primaries . That's all I can think of...
[Modified by Big Phat R, 10:33 AM 11/21/2001]
Old Nov 21, 2001 | 09:02 AM
ITR-01-0977's Avatar
New User
Default Re: Bottomed out my car, smacked header. What to check for? (Big Phat R)
Chris, check the jdm header hanger that is under your car to make sure it is not bent,also check the top exhaust manifold bolts(to your head) for loosening or cracking. You are probably fine though.
Old Nov 21, 2001 | 11:16 AM
nsxtcjr's Avatar
New User
Check the head on the nut that holds the steering wheel. If it hit the roof of the car, the head might be cracked.
Old Nov 21, 2001 | 11:32 AM
onyx00's Avatar
Default Re: Bottomed out my car, smacked header. What to check for? (ITR-01-0977)
Mark, I don't have the bracket that holds the header on, it's on order from IPS Racing, it's a hard piece ot get. I took an initial look and everything seems fine under the car. The lower heat shield is slightly dented so hopefully the header is fine. I will check the exhaust manifold tommarrow morning. I hope it's all okay.
Old Nov 21, 2001 | 01:57 PM
ITR632's Avatar
Make sure your heart's not still in your throat......
Old Nov 21, 2001 | 08:37 PM
905_S2K's Avatar
New User
Big Phat R: I feel for you. I ALSO flattened the 2 Primaries on my Spoon header on who knows what??
Oh well, i think i'm gonna try the Toda header, IF i can find someone to buy my Spoon.
Old Nov 21, 2001 | 08:55 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: Bottomed out my car, smacked header. What to check for? (Mugen-EG6)
I'll take it off your hands for 50 bux.
Old Nov 21, 2001 | 09:09 PM
TypeR 599's Avatar
Default Re: Bottomed out my car, smacked header. What to check for? (nsxtcjr)
hillarious hehe
deanBUG
Feb 1, 2007 09:45 PM
slowpokecivic
10
Nov 23, 2006 02:20 AM
baked_beanz
Apr 21, 2005 12:29 PM
aclw2
Apr 6, 2004 05:48 AM
Snail EG
Oct 19, 2002 05:47 PM
