how to: ek sideskirts on eg6???
Old Jul 8, 2004 | 01:27 PM
jdmitrhatch's Avatar
Default how to: ek sideskirts on eg6???
this looks hott...how do you make them fit on an eg hatch without it looking like ****....and i have no inner fender...thanks
Old Jul 8, 2004 | 01:58 PM
eg92b16a2's Avatar
Default Re: how to: ek sideskirts on eg6??? (jdmitrhatch)
if your good with bondo couldn't you merge the front section of the eg sideskirt and the rear ek sideskirt together. or get some mudflaps.
Old Jul 9, 2004 | 05:59 PM
krazyprelude's Avatar
the best way to put on the sideskirts with it looking good is to have some mudguards for the front of the sideskirt the rear of sideskirt fit in great my friend has it on his hatch
Old Jul 9, 2004 | 06:38 PM
Vtec69_4life's Avatar
pull stock ones off....and you will notice that 2 clips line up from the ek side enough to hold in place then i used tin snips to line up rear and filed them down and clip rear in. Drill a whole in front sideskirts to line up with the prior whole for stock sides and screw in. Mine look good:D
Old Jul 9, 2004 | 08:56 PM
jdmsiR20's Avatar
Default Re: (Vtec69_4life)
https://honda-tech.com/zerothread?id=142946
and you're set!
edit......... 999
Old Jul 9, 2004 | 08:58 PM
i was looking for that link
Old Jul 9, 2004 | 10:09 PM
Egone's Avatar
Default Re: (jdmsiR20)
well if u know someone who does autobody my friend cut his in the middle then molded them together that way theres no gap in the front he also said the skirts line up perfect with the eg mounting holes
superiorx120
Jun 18, 2015 05:35 AM
bikewithnoname
Jun 5, 2009 04:20 PM
lgn1281
Oct 27, 2006 07:18 AM
kcjohnnyboy
Welding / Fabrication
Aug 23, 2005 08:49 AM
