how to: ek sideskirts on eg6???
this looks hott...how do you make them fit on an eg hatch without it looking like ****....and i have no inner fender...thanks
Re: how to: ek sideskirts on eg6??? (jdmitrhatch)
if your good with bondo couldn't you merge the front section of the eg sideskirt and the rear ek sideskirt together. or get some mudflaps.
the best way to put on the sideskirts with it looking good is to have some mudguards for the front of the sideskirt the rear of sideskirt fit in great my friend has it on his hatch
pull stock ones off....and you will notice that 2 clips line up from the ek side enough to hold in place then i used tin snips to line up rear and filed them down and clip rear in. Drill a whole in front sideskirts to line up with the prior whole for stock sides and screw in. Mine look good:D
Re: (jdmsiR20)
well if u know someone who does autobody my friend cut his in the middle then molded them together that way theres no gap in the front he also said the skirts line up perfect with the eg mounting holes
