Questions for JDM Sterring Wheel owners.
Old Nov 20, 2001 | 09:27 PM
CWITR's Avatar
Default Questions for JDM Sterring Wheel owners.
1. What affect if any is there for the piece with the two holes and the arrow pointing up being changed to a different angle when putting on the steering wheel?
2. How tight do you put on the nut that holds the wheel on? It was on pretty tight, but I do not want to mess up the steering.
Thanks
Old Nov 20, 2001 | 10:04 PM
t's Avatar
t
Default Re: Questions for JDM Sterring Wheel owners. (CWITR)
its been a while since I changed out the steering wheel, but I think what you are describing with the arrow is the cable reel. If it is the cable reel, you dont use that part with the aftermarket wheel.
Old Nov 20, 2001 | 10:07 PM
CWITR's Avatar
Default Re: Questions for JDM Sterring Wheel owners. (t)
Why is that?
Old Nov 20, 2001 | 10:11 PM
koy's Avatar
koy
New User
you putting a jdm srs wheel on?
Old Nov 20, 2001 | 10:32 PM
CWITR's Avatar
Default Re: Questions for JDM Sterring Wheel owners. (koy)
Yes
Old Nov 20, 2001 | 10:35 PM
t's Avatar
t
Sorry, than you need the cable reel, I was assuming you were installing a non-airbag wheel.
Old Nov 21, 2001 | 04:43 AM
2k1TypeR0610's Avatar
New User
If you don't align it as per the Bible, you will break the real when you turn at full lock. The reel has maximum amount of turns. If you don't set the wheels straight and then allow for an even amount of turns to each side you will snap the reel.
Old Nov 21, 2001 | 09:52 AM
CWITR's Avatar
Default Re: Questions for JDM Sterring Wheel owners. (2k1TypeR0610)
Where can I get a cable reel that is compatible? Instead of the two prong being at an angle, they horizontal. What does the cable reel do exactly?
Old Nov 21, 2001 | 09:55 AM
Benjamin Tang's Avatar
are u sure u have an itr wheel? it could be for a civic-r... check if the hub matches with the splines on the steering shaft first.
Old Nov 21, 2001 | 09:58 AM
New User
Default Re: Questions for JDM Sterring Wheel owners. (Benjamin Tang)
Thae cable reel keeps the horn and airbag wires from wrapping around the steering column when you turn; therefore, eliminating the risk of sheared wires.
Old Nov 21, 2001 | 10:04 AM
CWITR's Avatar
The wheel does slide onto the column with out a problem. The prongs are just at a different angle.
Old Nov 21, 2001 | 06:16 PM
CWITR's Avatar
So, does anyone have any suggestions on what to do?
Old Nov 21, 2001 | 06:57 PM
machgo5go's Avatar
I went through the same BS with this last summer with my R and everybody tells me different. Some tells me no problem rotating the cable reel to align it with the JDM 98specR momo because u just end up having delay one side with signal return and some tells me it would break the reel because now u end up turning less on one side on full lock to lock. I had it, so i gave it back to the kid who were selling it. I didnt want to risk breaking a over $200.00 Cable reel to find out.
ed lee
Y2K ITR #498
97 ITR #315 RIP
Old Nov 21, 2001 | 08:32 PM
D's Avatar
D
Default Re: Questions for JDM Sterring Wheel owners. (machgo5go)
$200 for a cable reel? where the **** are you buying your parts?
D
Old Dec 10, 2001 | 10:43 PM
CWITR's Avatar
There is plenty of play in the cable reel from side to side past that which the steering wheel can turn. Have had no problems at all. the horn still works and the SRS light has not come on. The only thing is the directionals do not pop off when turning certain dirctions.
cameracutie11
Sep 2, 2011 09:06 AM
floatfisher
Jun 7, 2008 04:30 PM
ch00dlz
Jan 3, 2006 07:37 PM
DooD
Sep 22, 2005 09:56 PM
JDM EJ1 95
Sep 24, 2004 03:46 PM
