steering wheel
Old Jul 8, 2004 | 07:16 AM
devilpuppy's Avatar
Default steering wheel
u know when u turn ur wheel goin on a curve or soemthing and u let it go...it starts to turn back around, well wit this accord 5 speed, when i'm goin on a curve and i turn the wheel, i can actually let go and the car will keep goin on teh curve perfectly....sint' the wheel suppose to spin back?
Old Jul 8, 2004 | 07:43 AM
The_Todd's Avatar
Farts in the shower
Default Re: steering wheel (devilpuppy)
engrish?
Old Jul 8, 2004 | 08:09 AM
JDM.Accord's Avatar
Okay, I think he's saying that when he turns the steering wheel (while driving) he can let it go and it won't move (re-align itself so the car straightens out). That's my best guest but I only speak limited ghetto canadian, eh.
Anyway...have you lost power steering or is it just sticking like this?
Old Jul 8, 2004 | 09:23 AM
devilpuppy's Avatar
Default Re: steering wheel (JDMAccord2nr)
hhaha....sorry, i thought it was pretty clear....yea that is wat i'm tryin to say...that it dones't straighten out by itself
Old Jul 8, 2004 | 09:35 AM
TouringAccord's Avatar
H-T Order of Merit
even if you lose power steering the car will straighten itself out. It has to be something else.
Old Jul 8, 2004 | 11:18 AM
JimBlake's Avatar
Default Re: steering wheel (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">... It has to be something else.</TD></TR></TABLE>Like maybe alignment??
Old Jul 8, 2004 | 11:54 AM
Starrman85's Avatar
Default Re: steering wheel (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Like maybe alignment??</TD></TR></TABLE>
doh! thats too easy, it COULDN'T be that.
Old Jul 8, 2004 | 07:54 PM
devilpuppy's Avatar
Default Re: steering wheel (STARRMAN85)
would it be alignmetn? if im goin on a straight road and let go of the wheel...the car drives straight....so i dont htink its teh alignment
i was thinking the tires....but they are stock tires wit the 15 inch stock rims
Old Jul 8, 2004 | 08:52 PM
SuNDaY DRiVeR's Avatar
my absolute guess?? somthing to do with ur steering column.. maybe there's some bad beerings in there dat need lubing up with some heavy duty olive grease...
Old Jul 8, 2004 | 09:03 PM
accordnut's Avatar
Default Re: steering wheel (SuNDaY DRiVeR)
Check your ball joints, if one is seized the car will not return to centre. The best way to check them is to remove the outer tie rod from the steering knuckle and try turning the wheel it should be easy.
Old Jul 9, 2004 | 03:32 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilpuppy &raquo;</TD></TR><TR><TD CLASS="quote">would it be alignmetn? if im goin on a straight road and let go of the wheel...the car drives straight....so i dont htink its teh alignment</TD></TR></TABLE>Caster, camber, & steering axis inclination all contribute to that self-centering that you're missing. If that stuff is set wrong, but it's the same side-to-side, then it won't pull.
Could be seized ball joints, or a seized rack. Lift the front end & see if the steering works nice & smooth. Without extra friction. We can't tell that from here.
Old Jul 10, 2004 | 08:29 PM
devilpuppy's Avatar
when i turn left it happens all teh time....if i turn teh wheel to the right...it happends sometimes...but sometimes the wheel straightens out
dunno if that could lead to anybody giving more solutions
thanks
Old Jul 10, 2004 | 08:54 PM
FatJoe's Avatar
ur power steering rack could be going out... sometimes those pistons inside get stuck and you need to move em urself... have all ur steering components checked out
beans45883
Jun 16, 2017 06:35 AM
migizzel
Dec 5, 2005 08:10 PM
Turbo Squid
Aug 15, 2005 07:08 PM
