Honda S2000 Honda S2000
Anyone else have/heard of "air injection" trouble codes??
Old Jul 8, 2004 | 05:42 AM
B18CXr's Avatar
Default Anyone else have/heard of "air injection" trouble codes??
P0411 (60)
"secondary air injection system incorrect flow"
and
P1410 (60)
"air pump malfunction"
I can hear the air pump running when the car is cold started.....
Any ideas?
Old Jul 8, 2004 | 06:04 AM
Project SSAP1's Avatar
Default Re: Anyone else have/heard of "air injection" trouble codes?? (B18CXr)
yup...i always hear that damn suckign noise when i start the car in the mornings....it goes away after about 1 minute
Old Jul 8, 2004 | 10:27 AM
B18CXr's Avatar
Default Re: Anyone else have/heard of "air injection" trouble codes?? (Project SSAP1)
????????? WTF ????
I'm asking for anyone's input as to what the possible root cause of these codes could be, not the normal sounds of a code free start-up.
FYI:
Airpump and it's relay check out fine.
Old Jul 8, 2004 | 12:07 PM
cmdr430's Avatar
jack, i just called and emailed my friend that works at honda/acura this thread, maybe he has some ideas.
i will let you know, or he will get in touch with you.
cameron
Old Jul 8, 2004 | 02:08 PM
evil vapor's Avatar
how did you check the relay and pump? was it ever removed and reinstalled b/w having the engine running? all hoses are connected properly? Vacumn lines are connected properly to the purge valve and canistor?
Old Jul 12, 2004 | 06:13 AM
B18CXr's Avatar
Default Re: Anyone else have/heard of "air injection" trouble codes?? (vapor)
every single thing checks out fine and all lines are routed correctly....I just can not seem to figure this one out....
pump and relay were not touched prior to the code being thrown
Old Jul 12, 2004 | 11:36 AM
stevel's Avatar
i've heard of the P0411 code occurring when the gas cap doesn't seal tight enough or is loose.
s
Old Jul 12, 2004 | 06:47 PM
speed4tu's Avatar
I removed my air pump after I installed my test pipe. It thought that the converter never warmed up, so it ran all the time. Have you recently added a CAI and accidentally got the vaccum lines crossed?
Old Jul 12, 2004 | 09:30 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">
what was done prior to the code popping up? any mods? There have been instances that the pump itself has failed or become faulty. If the vacumn hose that connects to the purge valve and canister is hooked up backwards, the same code will be on.
Old Jun 9, 2005 | 08:45 AM
no2psi's Avatar
What was the conclusion to this problem? I have a s2000 at my shop that throws
a p0411 intermitently. Every thing seems to check out fine. The car does have a
cold air intake. Any suggestions would be appreciated.
Stormageddon
Jul 22, 2017 07:20 PM
JUSTINTHECOASTI
Honda S2000
30
Oct 24, 2011 12:56 PM
c-rex23
Honda S2000
Mar 10, 2010 10:29 PM
realblag
Honda S2000
11
Apr 15, 2007 02:06 AM
w
May 8, 2005 04:22 PM
