code 43 on obd0 exist?
Old Jul 7, 2004 | 11:19 PM
Jockobo's Avatar
Default code 43 on obd0 exist?
i get 4 slow blinks and 3 fast ones. this is on a 89 civic with a ls swap. 91 integra ecu. whats the problem?
Old Jul 8, 2004 | 03:11 AM
SETI20's Avatar
Default Re: code 43 on obd0 exist? (Jockobo)
o2 sensor. I had it too.
Check the wires and the grounds (if it has any).
If that still doesn't fix it, take a multimeter, and measure the output voltage. Should be around 0.8V at WOT, and 0.2 if you let go. Idle is usually a bit wacky because ove rich conditions.
If all else fails, replace.
(this is in the manual too)
Old Jul 8, 2004 | 10:39 AM
Jockobo's Avatar
Default Re: code 43 on obd0 exist? (SETI20)
cool thanks
91A-SPEC-ED-HATCH
Jul 20, 2012 12:40 PM
fryguy190
Mar 16, 2008 10:21 PM
91GS-R in Vegas
Dec 20, 2007 04:55 PM
northemt88
Nov 18, 2007 10:30 PM
