help with 92 sohc zc swap!
Old Jul 7, 2004 | 06:04 PM
civic1189's Avatar
Default help with 92 sohc zc swap!
I have a 89 honda civic dx and i am doing the dpfi to mpfi swap. i got a 92 sohc vtec engine and i am runing a pm6 obd0 system. my problem is that i can not get it to crank up. i tryed a 92-95 obd1 sohc vtec dis, and it crankedup but the rev limiter kicked in at 2500 rpm. so i tryed the 88-91 obd0 civic si dis and it did nothing it dosen't even bolt up. so now i dont know what to do i'd be thankful any help
ps is there a difference between obd0 and 0bd1 injectors
thanks walter
Old Jul 7, 2004 | 06:12 PM
mr. carpenter's Avatar
Default Re: help with 92 sohc zc swap! (civic1189)
there are some pics in this thread of how i got my dist. mounted. i think the injectors are the same?
https://honda-tech.com/zerothread?id=908656
Old Jul 8, 2004 | 12:46 PM
civic1189's Avatar
Default Re: help with 92 sohc zc swap! (mr. carpenter)
but the obd0 dis will not crank the car up but the obd1 will is there a difference between the two
Old Jul 8, 2004 | 01:37 PM
KOOL-AID's Avatar
maybe when you change back over to the obo-0 dizzy you might be wiring the two white wires backwards that might be a problem
Old Jul 8, 2004 | 02:06 PM
civic1189's Avatar
Default Re: help with 92 sohc zc swap! (KOOL-AID)
thought about that still does not crank.
Old Jul 8, 2004 | 03:17 PM
civic1189's Avatar
is there a differnce between the 88-91 si obd0 dis and the 92-95 sohc si obd1 dis
besides the bolt pattern
relly need help!
Chino12
Nov 2, 2015 07:10 PM
t-town_ep
Feb 28, 2012 06:08 AM
sohcvtec66
Apr 22, 2005 12:44 AM
spiceisler
Mar 11, 2003 01:26 PM
daniel89civ
Sep 13, 2002 10:42 AM
