Need Help.....
1990 CRX Si B16a1/S1/PWO
Fluctuating idle between 300-1000 rpm
Sometimes stalls at idle
Tach has begun to bounce a little when revving (barely)
Idle adjust screw all the way in = worst idle
Idle adjust screw 1 full turn out = a little better idle
Vacuum lines are correct
Slight hesitation when you barely touch the throttle
When driving, runs great
No codes
VTEC kicks in as it should
New cap, rotor, plugs, wires
Cannot accurately check timing while idle is fluctuating (timing marks move back and forth)
Hard to tell, but it almost sounds like it misses or backfires a little
Can you guys give me a hand with this? Or if anyone is from San Antonio/Austin I would be willing to come to you (and buy the beer ) if you could help me out.
No codes
could be your tps(throttle possesion) sensor, or iacv(idle air control valve). unplug the iacv and see if its still doin the problem, if it goes away its probly no good or has to be cleaned. iv picked one up on ebay for 10 bucks shipped
hope that helps
hope that helps
Had same problem with swap did recently make sure to check wiring and make sure that it is in the correct position most honda connections are the same style plug. also check the TPS and MAP sensors you could still have a bad map and not have a check engine light. Any honda MAP sensor will work off of 95 and older civics/crx ect. TPS should also work off of "d" or "b" series engines same yaers make sure it is not clocked wrong. Good luck let me know if it works or not I still have more ideas.
-Ignacio
-Ignacio
-Ignacio
MAP good, TPS set, wiring 100%, vacuum 100%. Found out that my timing is 30 degrees above TDC....
I don't understand why it runs so damn good if that is the case....
-Ignacio
b20eg9daddy
Oct 25, 2008 12:37 PM
twisted civic
Jul 17, 2008 08:08 PM
Civic Racer X 7
Jul 23, 2003 07:19 AM
