Thermostat?
Old Jul 7, 2004 | 01:10 PM
pumafeet10's Avatar
Default Thermostat?
Does Anyone kn ow where i can get a thermostat for my accord one that has a lower temp. To prevent overheating im getting a c and r radiator and want the lower thermostat!
Old Jul 7, 2004 | 01:49 PM
Robot Sonic's Avatar
Default Re: Thermostat? (pumafeet10)
hey mister, Mugen makes a low temp. thermostat.
check out this thread, there is a lot of talk of mugen products here...
https://honda-tech.com/zero...08045
then when your done here, go to:
http://www.kingmotorsports.com...ngine
write them an email and ask them the exact specs on your car and whether or not they have a lower temp. thermostat for you. ok?
Old Jul 16, 2004 | 10:26 AM
Default Re: Thermostat? (Robot Sonic)
did u ever find the thermostat you were looking for? was the information good and valid?
Old Jul 16, 2004 | 11:12 AM
TouringAccord's Avatar
H-T Order of Merit
I think TASAuto sells a 160deg thermo. I beleive the stock thermo is 174-180deg, something like that.
edit:
yep, they still have them. 160 degree thermostat for $11.20
http://www.secureleadercom.com...age=2
Old Jul 16, 2004 | 11:57 AM
propwdialogue's Avatar
Default Re: Thermostat? (TouringAccord)
well looks like your question has been answered so im gonna jack this and ask my own question right quick. im new to thermostats and all that junk and i suspect that the previous owner put in a different thermostat than just a replacement because in the winter i can hardly get my temp guage to go much above the bottom slash, but in the summer it stays just below the mid line. anyone have an idea what temp thermostat was put in and what temp one i should put in for the winter? (cause it gets cooooooold, especially when you cant get your car to warm up)
Old Jul 16, 2004 | 01:16 PM
shrekz's Avatar
Default Re: Thermostat? (propwdialogue)
what is the normal temp thermostat, i have a 192 degree in there right now and the fan turns on after i shut off the car, i think the thermostat could be the problem. i think i will get it direct from honda.
Old Jul 16, 2004 | 02:17 PM
RotaryBzzzz's Avatar
Default Re: Thermostat? (shrekz)
a lower temp thermostat will decrease your gas mileage.
Old Jul 16, 2004 | 02:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shrekz &raquo;</TD></TR><TR><TD CLASS="quote">what is the normal temp thermostat, i have a 192 degree in there right now and the fan turns on after i shut off the car, i think the thermostat could be the problem. i think i will get it direct from honda.</TD></TR></TABLE>
that's normal. If anything, it would be your coolant sensor.
90civicbns
Jul 9, 2013 04:36 PM
iperez
Jan 2, 2004 02:42 AM
JRSC EM1
Jul 10, 2002 09:11 PM
