can any one tell me how 2 hook up the v-tec to the ecu
Old Jul 7, 2004 | 11:35 AM
barry11j's Avatar
Default can any one tell me how 2 hook up the v-tec to the ecu
i have a 91 crx si ... im just about done doing my swap( b16A).. can some 1 plzzzz tell me how to hook up the v-tec and also an easy layout 4 the easiest way to change out the timing belt..thanx
Old Jul 7, 2004 | 11:39 AM
4drEF's Avatar
Keyboard Humorist
Default Re: can any one tell me how 2 hook up the v-tec to the ecu (barry11j)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by barry11j &raquo;</TD></TR><TR><TD CLASS="quote">...easiest way to change out the timing belt..thanx</TD></TR></TABLE>
You should have done that before you put the motor in.
Old Jul 7, 2004 | 11:44 AM
barry11j's Avatar
Default Re: can any one tell me how 2 hook up the v-tec to the ecu (4drEF)
well the motor is in....all i have left to do is change out the t-belt, set timing, hook up exh. s-linkage and v-tec to the ecu
Old Jul 7, 2004 | 11:46 AM
barry11j's Avatar
also....what other throttle position sensors will work for the b16A...the one that came w/my swap is damaged?!!
turboteg90
27
Jun 20, 2008 01:46 PM
jetlude
Apr 30, 2007 06:01 PM
bird00420
Mar 30, 2007 12:20 PM
boostin4door
May 31, 2005 04:47 AM
PolySquared
Dec 17, 2003 12:32 PM
