Tech Question
Old Nov 20, 2001 | 04:21 PM
NSX Bob's Avatar
New User
Default Tech Question
If I reset the ECU by disconnecting the battery cable, will I have to reset my V-AFC too, or will the settings remain for a while? I don't want to have to reprogram the V-AFC, but I need to reset the computer. Thanks.
Old Nov 20, 2001 | 04:24 PM
yoshi234's Avatar
I shoot brides
Default Re: Tech Question (Itr00-1374)
why not just pull the fuse for the ECU to reset it?
Old Nov 20, 2001 | 04:26 PM
Austin's Avatar
No you will not have to reprogram the VAFC, and you should pull the fuse that Yoshi is referring to in your main fuse box by the battery.
Austin
Old Nov 20, 2001 | 04:31 PM
NSX Bob's Avatar
New User
Is that fuse marked as the ECU in the fuse box? I'll definetly do that, I just didn't know it was there. Well, I guess you never stop learning......
Old Nov 20, 2001 | 06:18 PM
FSTASNTZ's Avatar
Do either one, you will not have to reset the APEX-i unit. It will be just fine...
Jason
allmotorsi04
Jul 11, 2004 03:08 AM
9civic8
Apr 2, 2004 08:51 AM
2dark2bslow
Nov 27, 2003 08:58 PM
NoLipRacen
Jan 29, 2003 05:16 PM
SIK IN DA HED
Oct 27, 2002 08:42 PM
