Brake lite is on
I got 00civic EX with 35000 miles on it. One day I was driving and brake light came on. It stays on and when I hit brake it goes for while and than comes on again. My car takes long time to stop too. It is not making any noise so I don't think its my brake pads.
Can some one help me out here.
Modified by Jaydeep at 5:55 PM 7/7/2004
check your brake fluid. If its low in the reservoir then the brake light will come on to tell you that your brake pads are on the way out, thus the low fluid level.
Pads/disk ware down takes more fuild to push them all the way in. If you repalce the pads then less travel means higher fluid level. 98ctr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ctr »</TD></TR><TR><TD CLASS="quote">check your brake fluid. If its low in the reservoir then the brake light will come on to tell you that your brake pads are on the way out, thus the low fluid level.
Pads/disk ware down takes more fuild to push them all the way in. If you repalce the pads then less travel means higher fluid level. 98ctr</TD></TR></TABLE>
bingo!
bingo!
Fluid level is normal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaydeep »</TD></TR><TR><TD CLASS="quote">I got 00civic EX with 35000 miles on it. One day I was driving and brake light came on. It stays on and when I hit brake it goes for while and than comes on again. My car takes long time to stop too. It is not making any noise so I don't think its my brake pads.
Modified by Jaydeep at 5:55 PM 7/7/2004</TD></TR></TABLE>
how can you see your brake lights if you are driving the car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECMaster »</TD></TR><TR><TD CLASS="quote">LMAO no he meant that warning light in his dashboard, next to your speedometer </TD></TR></TABLE>
Well if the parking brake/low fluid indicator light is what he was talking about, then if the brake fluid level is fine, go check the switch on the handbrake. You will have to remove the boot to reach it and adjust it or check if the switch is grounded.
and again i will use this ....
jaydeep you have a lot of these kinda posts huh??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaydeep »</TD></TR><TR><TD CLASS="quote">How much it would be if I want to import type r civic 2000 from japan. What is the procedure. Is is too much work to do all paper work and everything. "
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaydeep »</TD></TR><TR><TD CLASS="quote"> I put AEM cold air intake in my car (civic EX 2000) today. Now when I start my car it make noise. I think noise is coming from air filter. Can some one help me out here.
I installed air intake in my friends car long time ago. His car maid same noise. I forgot what we did to fix it.
SiKid86
Oct 24, 2005 07:41 PM
rockwilda
Oct 16, 2002 12:09 PM
