Need a replacement fan. Need info
Old Jul 7, 2004 | 07:50 AM
6MTV6's Avatar
Default Need a replacement fan. Need info
What's the largest fan I can replace my radiator fan with? I'm looking at Perma-cool 14" fans. I know a 12" will fit, I was wondering if anybody's gone with something bigger.
Since my Civic has a B16 in it, with A/C, I have virtually no room on the driver's side in front of the EXM. There's some sort of cooling core in front of my radiator, it looks like part of my A/C, so there's no room on the front driver's side of my radiator either(I was going to put a slimline push fan, no room). My A/C fan is piggybacked to my radiator fan, causing me to overheat when I'm sitting in traffic. Phoenix summers suck ***.
So I figured I could keep this set-up if I replace my stock radiator fan. The Perma-cool 14" is shown on Alamomotorsports.com as a Honda Application. It only draws 9 amps, and is fused to 30A. Plus it pulls 2950 CFM!!
I just need to know if anybody has done this....
Old Jul 7, 2004 | 10:20 AM
spaceman's Avatar
Default Re: Need a replacement fan. Need info (Bishop4G)
have you checked out FAL fans?(i think thats the company name)
Old Jul 7, 2004 | 10:42 AM
spiceisler's Avatar
Default Re: Need a replacement fan. Need info (spaceman)
I have (2) 10" pusher fans from Ebay. I paid like $65bux for them. One wired to the original harness the other wired to a manual switch on my 90hatch. Works great!
Old Jul 7, 2004 | 10:43 AM
6MTV6's Avatar
Default Re: Need a replacement fan. Need info (clean90Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean90Si &raquo;</TD></TR><TR><TD CLASS="quote">I have (2) 10" pusher fans from Ebay. I paid like $65bux for them. One wired to the original harness the other wired to a manual switch on my 90hatch. Works great!</TD></TR></TABLE>
Do you have a B16? If not, you don't have the header clearance issues I'm having...
Old Jul 7, 2004 | 11:02 AM
spiceisler's Avatar
My bad, I did'nt read your post properly. I have a Zc. My pusher fans are infront of the condenser right behind the bumper support.
Old Jul 7, 2004 | 12:30 PM
6MTV6's Avatar
It fits there? Then the header clearance shouldn't even matter. I need to jack up my car and start looking at what can be bent out of the way.
I'd still like to get a 14" pull fan for my radiator.
Anybody got any info on this???
knakmuhs
Aug 13, 2010 04:44 AM
unknow
Dec 9, 2009 03:05 PM
GRANT!
Oct 27, 2009 03:37 PM
tsmith0819
May 22, 2006 03:59 AM
Rah Rah
Aug 4, 2003 09:00 PM
