Compression Question for all motor freaks...
Old Nov 20, 2001 | 03:22 PM
newspeedR's Avatar
Default Compression Question for all motor freaks...
Is it possible to run a gsr block with ctr pistons with a ITR head, milled 20thousands with Toda B's
I am not sure if the head it going to to be close and cause a vavle tap... if so.. what size head gasket could be used... ie toda
Thanks...
Old Nov 22, 2001 | 08:03 AM
PROFILE EK4's Avatar
New User
Default Re: Compression Question for all motor freaks... (newspeedR)
no one out there knows????????
supposibly a stock full headgasket would just clear it......someone has to know the answer to this.....
Old Nov 22, 2001 | 08:17 AM
Big Phat R's Avatar
You should have the shop assembling the motor clay the motor to verify this prior to assembly. Then you will be able to determine a safe gasket thickness.
Why are you milling the head?
Old Nov 22, 2001 | 08:58 AM
New User
Default Re: Compression Question for all motor freaks... (Big Phat R)
our friend who is buying this head....is gonna do the install...but he wants to make sure that the pistons are gonna clear the head....hes been told it would clear but wants to make sure before he sticks em on...
panykus
15
Sep 19, 2004 08:55 PM
G-money
Nov 27, 2003 11:33 PM
iblewmyrmotor
Apr 14, 2003 07:48 AM
Beave0101
Jan 1, 2003 06:35 PM
TypeR0149
Feb 24, 2002 07:12 AM
