widest tires on an eg coupe?
Old Jul 7, 2004 | 03:13 AM
Boostage's Avatar
Default widest tires on an eg coupe?
are 205's the widest I can go without rubbing in a U turn?
Old Jul 7, 2004 | 05:44 AM
JinDIESEL's Avatar
Default Re: widest tires on an eg coupe? (Boostage)
I have 7.5" width rims.. i dont scrape when doing a u turn.. mayb 8 is the max or 7.5"
Old Jul 7, 2004 | 05:52 AM
s1ngle's Avatar
Default Re: widest tires on an eg coupe? (JinDIESEL)
The rims are not the main factor... tire size is also important...
Jin, what size tires are you running?
Old Jul 7, 2004 | 06:15 AM
FERIOkid's Avatar
Default Re: widest tires on an eg coupe? (s1ngle)
i have 205/50/15 and i rub turning into parking spots, u turns, and over small bumps slowly ...But it's all worth it
Old Jul 7, 2004 | 04:16 PM
Boostage's Avatar
Default Re: widest tires on an eg coupe? (slowdx9585)
ok so no bigger that 205' right?
Old Jul 7, 2004 | 04:21 PM
toolowsol's Avatar
depends how low you are, and what your rim offset is, You could go stock ride hieght, and some crazy offset and run 275's... but it would look retarded
Old Jul 7, 2004 | 04:43 PM
tallblondkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowdx9585 &raquo;</TD></TR><TR><TD CLASS="quote">i have 205/50/15 and i rub turning into parking spots, u turns, and over small bumps slowly ...But it's all worth it </TD></TR></TABLE>
but how low is your car
Old Jul 7, 2004 | 05:01 PM
FERIOkid's Avatar
Default Re: widest tires on an eg coupe? (tallblondkid)
check out my sig...
Old Jul 7, 2004 | 05:08 PM
shakedown94's Avatar
my 225-50-15 will be here tomorrow for the front. will let ya know how it goes when they go on. don't mind beating the fenders out alittle,already have some. it is only a auto-x car.
it sits 2" lower than stock right now with 35 offset kosei right now.
Old Jul 7, 2004 | 05:12 PM
Tad's Avatar
Tad
depending on how low you are,
yeah I could see you running 225's without overbearing rubbing problems.
with properly rolled fenders of course.
I'd be more worried about rubbing on the inner fender and suspension arms than the outer fender(the one you roll) though.
Old Jul 7, 2004 | 06:28 PM
Default Re: (Tad)
if needed, i'll end running a 5mm spacer. but would rather not if i can help it.
i would rather have a 225-45-15,but can not afford dot-r tires every 10k miles.
as for the fender rolling,got a rubber mallet and wood bat ready.
oh well back to the never end project.
Old Jul 7, 2004 | 07:36 PM
inane's Avatar
my 205/40/17 dont rub at all, car is lowered 1/2"
Old Jul 7, 2004 | 07:44 PM
Tad's Avatar
Tad
Default Re: (shakedown94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shakedown94 &raquo;</TD></TR><TR><TD CLASS="quote">if needed, i'll end running a 5mm spacer. but would rather not if i can help it.
oh well back to the never end project.</TD></TR></TABLE>
mmmm, be careful with fender rolling,
when bending the metal in, it can/will easily crack the paint along the rim of the fender.
I've heard using a heatgun can prevent this.
oh I should also note that you can get 215-45-15 toyo t1-s,
its a kinda old tire now,
but has been proven to provide very good grip,
not azenis level, but very good, and that tire size is really nice!
running that on a 15x7 tire would be awsome.
do a google search, saw em at one place for like $112 each.
Old Jul 7, 2004 | 07:57 PM
toadolson's Avatar
Default Re: (Tad)
Running 215/45/16 on a 2.25 lowered car. Had neuspeed sport on the car with a 1" gap per tire. Now on GC and the tires are not tucked, but close.
Old Jul 7, 2004 | 08:10 PM
Tad's Avatar
Tad
Default Re: (toadolson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toadolson &raquo;</TD></TR><TR><TD CLASS="quote">Running 215/45/16 on a 2.25 lowered car. Had neuspeed sport on the car with a 1" gap per tire. Now on GC and the tires are not tucked, but close.</TD></TR></TABLE>
aaaand u rubbin at all?
fenders rolled or no?
Old Jul 7, 2004 | 09:00 PM
toadolson's Avatar
Default Re: (Tad)
Just a little on the inner sub-frame. No rolled fender, etc. But I'm running crazy spring rates, 450 front/ 550 rear. Not alot of suspension travel at all.
Old Jul 7, 2004 | 09:09 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toadolson &raquo;</TD></TR><TR><TD CLASS="quote">Just a little on the inner sub-frame. No rolled fender, etc. But I'm running crazy spring rates, 450 front/ 550 rear. Not alot of suspension travel at all.</TD></TR></TABLE>
those rates arent that crazy,
at least the front.
if you dont have a shortened shock, or extended mounts or something,
they you have no travel due to your drop.
but yeh, no travel will help with rubbing
i run 450/350 rates, and plenty of travel,
more rate in the front couldnt hurt.
your rear rate is pretty high actually which might be whats making em feel crazy,
you feel bumps alot if you have a stiff rear(theres no weight back there so the spring wont compress much.. you'll just feel the hit).
Old Jul 8, 2004 | 12:47 PM
toadolson's Avatar
Default Re: (Tad)
Have the GC upper extended mounts. Very nice. Once the scion Xb gets purchaced, then the 550 go up front and some 650-750 for the rear.
Old Jul 8, 2004 | 01:56 PM
fishnfst's Avatar
The three things that make the biggest difference in rubbing are ride height, wheel offset and amount of negative camber you are running.
Old Jul 12, 2004 | 10:35 AM
94solchick's Avatar
I have 7" tires, and when I turn fast, they rub the back fenders a little, I rolled the fenders, and now it's fine. I think it was just the rims and they didn't exactly fit right.
Old Jul 12, 2004 | 11:10 AM
turbotime's Avatar
i am running 205/50/16 and they rub takin corners fast and on uturns. I got GC's and the car is only lowered like an inch, but i think that 50 is too big for 16s so im trying to get some 205/40/16
Old Jul 12, 2004 | 06:54 PM
Default Re: (turbotime)
put the 225-50-15 on the car sat. after rolling the fender and slightly flaring the fender out it is not rubbing the fender. it does however rub on the frame on both ends of tires on hard turns and on the seam above the tire. it also rubs right in front and behind the shock, where the shock tower starts. i might raise the front slighty and section and beat flat the seam.
this is with gc with 450 front spring, gc upper shock mount,and koni shock.
it did not go as bad as i had thought
overall still wish someone made a 225-45-15 street tire.
Old Jul 12, 2004 | 07:06 PM
eg64u's Avatar
225's will rub for sure my car is dropped 1.5 inch and i have 205/50/15's on my civic and my fenders are rolled but thats not the thing it actually rubs the inside of your wheel well . It will rub down past the plastic then to the paint and to a metal shine after some u turns. but it is worth it when you have power and you need something to ground it with. I dont really u turn much and if i do i do a austin powers style thing or take it wide.
turboITR#704
Jun 20, 2007 11:33 AM
ToxicBug
Apr 27, 2005 06:55 AM
red civic standard
Oct 31, 2004 03:39 PM
E-spec Tuner
Jun 30, 2004 06:26 AM
zither
Jun 22, 2002 08:14 AM
