my jdm engine blown? =(
Old Jul 7, 2004 | 12:29 AM
asnboi_512's Avatar
Default my jdm engine blown? =(
ok.. here's the story.. im at work ( delivering chinese food) HAHA not funny.. im crossing i-35 intersection goin onto MLK st. and i hear pop.. car engine dies.. roll to a stop at the sidewalk.... i try cranking it a few times...it give me a little put..put..put.. and dies again.. i give it some more.. nothing i get out
check the engine for lose ignition wires.. or broken hoses and the belts.. everythings fine.. except the msd wire from the blaster II coil was thrown off the distributer.. i was thinkgin that was that poping sound? so then i take a screw driver stick it in that wire put it on the valve cover to see if i got a spark..i have my buddy crank it.. no spark.. am i doin it wrong or somthing.. i dont think so? its a jdm f20a dohc non-vtec.. is it time for the H22? / anyone have a blown motor? wat does it sound like when u try to crank it over? gawd this cars gettin on my nerves..
Old Jul 7, 2004 | 07:52 AM
bodiez's Avatar
Hit the floor!
Default Re: my jdm engine blown? =( (asnboi_512)
It doesnt sound liek a blown engine. Sounds more like an electrical problem. Make sure your plug/plugwires are good, alternator, coil, etc.. are all functioning on it. Also the cap/rotor/etc..
Old Jul 7, 2004 | 08:53 AM
Nick H's Avatar
New User
Default Re: my jdm engine blown? =( (bodiez)
when i blew up my old h22a, it sounded like KABOOOM! KaCLunk KaCLunk Pop Pop Pop Pop Pop, KaChunk! (this is where i need to add that blue smoke, oil, started pouring out from under my hood) and the car made some other Chunk Chunk noises.
I highly doubt you blew your motor
Old Jul 7, 2004 | 09:13 AM
secksiman19's Avatar
Default Re: my jdm engine blown? =( (Nick H)
no spark does not equal blown motor. it does not sound like a blown motor. if you saw smoke or smelled something i would worry, but you didnt right
Old Jul 7, 2004 | 09:25 AM
4thgen92accord's Avatar
I think ur Blaster coil screwed you. I have a 92 accord lx with the ole f22 and decided to put the blaster coil SS in place for my stock coil. Everything was fine, for about a week. A mustang gt(86-93) comes up next to me and is revving so i thought o well what if i get my *** handed to me. SO we take off form like a 55 roll , shift to third, probably get to about 5500 rpm and the engine shuts off...first thing i thought is i had thrown a rod. Im getting no spark at all. Long story short i check the blaster coil for resistance and its good. the stock coil i belives is suppose to be 18000-22000 ohms and the blaster coil read 44,000 ohms. Checked everything and still no spark so im stumped. the igniter tests good. Ended up getting a different dizzy, started up first crank. I'd get a diff. dizzy first.
Oh yea Also I'd put ur stock coil back on. I ditched my MSD Blaster SS coil and its for sale as we speak...15 dollars...haha. Its still good tho.
Old Jul 7, 2004 | 09:35 AM
asnboi_512's Avatar
Default Re: my jdm engine blown? =( (secksiman19)
when i was trying to keep cranking it over i saw smoke from the starter area maybe from the dist. cap or somthing?
Old Jul 7, 2004 | 09:45 AM
So its getting Fuel? Just no spark? If so, first thing i would do is put the stock coil back on, try it, and if that doesnt do the job, id say new dizzy.
asnboi_512's Avatar
Default Re: my jdm engine blown? =( (4thgen92accord)
wth's a dizzy? distributer cap?
Old Jul 7, 2004 | 09:46 AM
dizzy=Distributer itself
Old Jul 7, 2004 | 09:49 AM
asnboi_512's Avatar
i dont have the stock coil.. and i know its gettin fuel cause i can hear the fuel pump come on.. so im pretty sure its somthing with this gay msd ignition set up.. ARRrghh
Old Jul 7, 2004 | 09:53 AM
Is it an internal coil(inside the distributer, and u got an MSD cap to go with the MSD blaster coil) or is it an external coil(outside the dizzy)?
Old Jul 7, 2004 | 12:56 PM
asnboi_512's Avatar
its external..**** guys i just replaced cap, rotor, plugs, wires are still good and i replaced the coil with an accel universal 12volt coil after chaning the coil i noticed it amlost started.. gave a me a little cough like i kicked its *****. but now my battery's gettin low so im gonna try to put a lil more gas in the tank and get a jump.. pray for me..anyone else have any ideas?
Old Jul 7, 2004 | 01:10 PM
4genaccordfreak's Avatar
hopefully when the wire was knocked off of the dizzy u didnt jump a tooth... thats what happened to my buddy's h22 prelude.. the distributor siezed up and the motor jumped an exhaust tooth.. and there is most likely about 4-6 exhaust valves bent or broken.. it did the same thing as ur talking about.. we check for spark and yada yada.. changed to external coil.. nothing.. changed distibutor.. and still only turned over.. but wouldnt start.. did a compression test.. and it wasnt building anymore compression.. motor is fucked unless he did a whole new valve train.. so instead he bought a new motor.. hopefully thats not what happened to you.. cuz it seems VERY VERY similar
Old Jul 7, 2004 | 02:22 PM
asnboi_512's Avatar
Default Re: (4genaccordfreak)
my dad said that it might not turn over because its getting to much air.. i bored out my throttble body few days ago.. and just put new plug in last nite.. and now there black as hell already.. this mean im gettin to much air? and my timing is off? sence the plug isnt sparking at the right time.. this motor is being a bitch.. i need an h22 im desperate im goin usdm this time..
Old Jul 7, 2004 | 04:23 PM
RUBZERK's Avatar
Default Re: (asnboi_512)
Read this post. sounds like what happend to me.
https://honda-tech.com/zerothread?id=908396
Old Jul 7, 2004 | 07:11 PM
Nick H's Avatar
New User
[QUOTE=asnboi_512]and now there black as hell already.. this mean im gettin to much air? and my timing is off? QUOTE]
no, if they are black, that means you are getting too much fuel...the black is carbon deposits...
Old Jul 7, 2004 | 08:32 PM
asnboi_512's Avatar
Default Re: (Nick H)
how would it be gettin to much fuel.. its all stock fuel system just upgraded ignition and intake, header, exaust and bored throttle body i would have thought air would have been the case
Old Jul 7, 2004 | 11:36 PM
Nick H's Avatar
New User
no sir...notice when you are running too rich, that black smoke exits the exhaust and covers your exhaust with the black suit, otherwise known as carbon deposits...this is a sure sign of a rich a/f mixture...most likely, your 02 sensor sees the extra air going through the engine (due to ease of air flow you have created) and corrects itself by adding more fuel...
Old Jul 8, 2004 | 08:58 AM
asnboi_512's Avatar
hmm.. ic.. so u did a h22 swap on urs eh?.. i got a prelude si tranny.. h22 will bolt rite up correct? did u use a diff wire harness?
Old Jul 8, 2004 | 04:54 PM
Nick H's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asnboi_512 &raquo;</TD></TR><TR><TD CLASS="quote">hmm.. ic.. so u did a h22 swap on urs eh?.. i got a prelude si tranny.. h22 will bolt rite up correct? did u use a diff wire harness?</TD></TR></TABLE>
you need a prelude driveside mount that is ground down a little bit...the wiring harness was the oem accord harness with the prelude pieces and parts added in...i had to add vtec pressure, vtec selenoid, and knock sensor i believe...oh, if you were asking if the h22 will bolt to the h23 tranny, the answer is yes...
Old Jul 8, 2004 | 07:53 PM
asnboi_512's Avatar
alrite thanks alot everyone.. looks like the h22 project starts this weekend
ride5150
17
Mar 23, 2011 10:54 AM
6gsillyca
Nov 1, 2008 12:16 PM
Ideal
Nov 6, 2002 12:51 PM
skrewdlude
Mar 19, 2002 06:45 AM
