dash lights dont work any more.
Old Jul 6, 2004 | 10:45 PM
PHOBIA's Avatar
Default dash lights dont work any more.
ok ever since i hooked up my autometer tach in my 91 si the lights in the dash stopped working,my light dimmer switch wouldnt work for the light source so i figured that i did not need the little glow ring that goes around my cig lighter.so i spliced into that and used that power for my tach back light,i figured it only came on when the lights were on so it would be ok.well anyways i have checked the fuse thats labeld dash/ac controlls/dome light.well it kinda goes like this.the lights for the ac and heat dont light up anymore neither do the cluster lights.i took a volta meter to the wires runing to the auctual lights inside the gauge cluster and they were getting power just not working.is it possible that i just burnt the lights out?i took them out and they seemed just fine.wtf is going on.its been 2 months and i have no clue.please can some one help.is there a fuse under the hood?
Old Jul 7, 2004 | 09:20 AM
PHOBIA's Avatar
Default Re: dash lights dont work any more. (PHOBIA)
bump.
Old Jul 7, 2004 | 09:30 AM
EyelessCRX's Avatar
Definately check the fuses. Check under your steering wheel. Right below the Steering colum there is a panel that should say fuses. There are two tabs on that that you have to push in. Push those in and then look on the underside of the pannel for the fuse map. There is also a fusebox under the hood. When you pop the hood look up to the top left corner for the fuse box. I believe that the fuses that you are looking for are under the steering colum though.
Old Jul 7, 2004 | 11:20 AM
Donkey85's Avatar
Default Re: dash lights dont work any more. (EyelessCRX)
its fuse number 8 that is under the steering wheel on the fuse block below
Old Jul 7, 2004 | 07:35 PM
PHOBIA's Avatar
Default Re: dash lights dont work any more. (Donkey85)
yeah i checked under the dash and it is fine.if it was that particular fues the dome light would not work.once when i was dicking around with my stereo i had a live wire touch a ground and it blew out that fuse i replaced it and it was ok.so is there a fuse under the hood that would cause just those particular lights not to work?
Old Jul 7, 2004 | 07:57 PM
Donkey85's Avatar
negative, if i was in your shoes i would just pull every fuse out one at a time and see if you can find the dud fuse. you would be suprised by doing that and finding a fuse that is blown causing the problem even though the fuse that it should be blown is not. good luck
Old Jul 7, 2004 | 07:58 PM
PHOBIA's Avatar
checked under the hood and all is good.ive heard stories about these wires shorting out fairly easy.
Old Jul 7, 2004 | 11:14 PM
hahagasdcrx's Avatar
Your light dimmer may be out as well. If that goes out then you will have no gauge lights. Check to see if the dimmer switch is plugged in , getting +12v, check voltage output of it turned to its brightest setting.
Old Jul 8, 2004 | 11:56 AM
nautica_t's Avatar
Default Re: dash lights dont work any more. (hahagasdcrx)
my dash lights don't work either, but at least my control lights light up, as in the climate control lights, they actually come on, but i can't dim them or what not. Clock light doesn't even work properly, it just stays on, won't dim or what not. so i'm not even sure what my problem is either, Phobia if you find out, i'd like to know this answer as well. i checked all my fuses as well.
Old Jul 8, 2004 | 09:26 PM
PHOBIA's Avatar
well what had happend was when i was hooking the tach up it was getting dark so i turned the lights on and had the car running whal i was doing it.the last wire that i hooked up was the light source wire,when i selected the cig lighter glow ring and spliced into it it worked fine.but every time i would touch the wire to it the lights in the dash would go out.i touched it together about 5 or 6 more times swapping different wires and then i tried it one last time and they just wouldnt work at all.but the tach light is working still so those wires are getting power.well i guess i will tinker around with this p.o.s some more in a couple days,all that really matters is that my tack works at night but its pretty dark/inconvienet driving with out them.
Old Jul 10, 2004 | 06:32 PM
PHOBIA's Avatar
well,today i spent four hours on this thing.i ripped most of the dash apart trying to figure it out.i had positive power going to the cluster with no negative.it was all positive,it is getting power from some were were it should be grounded.i figured thet if i cut a wire from the harness going to the cluster and ground it,that it should work.it didnt so know im in a little deeper than i was before.any other ideas?
Old Jul 10, 2004 | 06:49 PM
Origin's Avatar
Default Re: (PHOBIA)
did you try what hahagasdcrx mentioned. when i ripped my dash out my gauges wouldn't work either and guess what it was.. the dimmer switch. check that.
Old Jul 11, 2004 | 09:23 AM
PHOBIA's Avatar
yeah after i re wire the part of the harness that i demolished im going to swing by the pick and pull and pick one up.
Old Jul 11, 2004 | 09:27 AM
PHOBIA's Avatar
but why would the dah have no ground? its all +. it just cannot work with out a ground.what i did was cut the red black wire behind the tach and tried to ground it.because every wire was positive.so i will try and reconnect theat then get the new dimmer switch.how do you know if it is going bad or not.a while back it would either be way bright or off with little to no play.I thought it was a little wierd but i didnt think about it until now.
Old Jul 18, 2004 | 09:56 PM
PHOBIA's Avatar
ok, i spliced the wires back together and i replaced the dimer switch with another one that came from a low milage civic that was in a wreck and they still dont work.any other ideas?.
i know my main relay is going to crap, could that have something to do with it?
Old Oct 4, 2006 | 07:55 AM
jdmrsferio's Avatar
damn me too now i changed all my bulbs in my dash n cluster my climate controller lights worked be4 i plugged in the cluster now all dont work and when i use my alarm he headlights dont flash... iono why now um but my climate controler flashes does anyone know how to fix it i need to fix it by tonight...
Old Oct 4, 2006 | 07:59 AM
philkehn's Avatar
I needed to fix mine by tonight about 5 weeks ago and mine still dont work, this is a crx main problem and i havent found any help on this subject from h-t
Old Oct 4, 2006 | 08:05 AM
jdmrsferio's Avatar
Default Re: (philkehn)
damn that **** sucks that my lights dont work ahh its tight all my interior is amber but it dont work ugghhh i just installed it too it looks soo nice ahh
Old Oct 4, 2006 | 08:06 AM
jdmrsferio's Avatar
Default Re: (jdmrsferio)
someone needs to help
Old Oct 4, 2006 | 09:00 AM
doublethink's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHOBIA &raquo;</TD></TR><TR><TD CLASS="quote">but why would the dah have no ground? its all +. it just cannot work with out a ground.what i did was cut the red black wire behind the tach and tried to ground it.because every wire was positive.so i will try and reconnect theat then get the new dimmer switch.how do you know if it is going bad or not.a while back it would either be way bright or off with little to no play.I thought it was a little wierd but i didnt think about it until now.</TD></TR></TABLE>
you are on the right track.
you need a multimeter.
the red / black wire goes POSITIVE 12 volts when you turn on your parking lights.
if you dont have positive 12 volts on that wire when your parking lights are on, check the fuses inside the car. if not the fuses then the wire is shorted from you tapping into it.
the dimmer control is a variable resistor to the GROUND side of the light circuit. theres usually 3 wires on the back of the dimmer:
1) a source ground of 100% strength.
2) the output gound to the dash lights
3) red/black positive for the tiny blub inside the dimmer switch itself if its a 90-91.
you need a multimeter or a test light, something that will show you if you have power or not, you cant guess this sort of thing.
with that knowledge you should be able to fix it, if not seek someone with more experience in your area to help you.
Old Oct 4, 2006 | 09:31 AM
jdmrsferio's Avatar
Default Re: (doublethink)
i found a blown fuse lets see moment of truth if it works or not
Old Oct 4, 2006 | 09:57 AM
jdmrsferio's Avatar
dash works cluster sont still wdf any help???
Old Oct 4, 2006 | 10:31 AM
teler86's Avatar
Default Re: dash lights dont work any more. (jdmrsferio)
i have the same issue, i tried replacing dimmer switch and it worked again for a day and then stopped, i have no clue how to fix this. subscribed cus i wanna know how to fix this.
Old Oct 4, 2006 | 10:33 AM
jdmrsferio's Avatar
Default Re: dash lights dont work any more. (teler86)
i woulnt think its my dimmer switch tho were u get 1 at?
Old Oct 4, 2006 | 11:39 AM
jdmrsferio's Avatar
expletive that **** its fixed alot of work but its finally done
Integra4lyfe069
43
Oct 11, 2017 09:57 AM
Tr4xX
Nov 23, 2012 01:47 PM
shoebox
Sep 28, 2012 04:39 AM
slob20ef
Mar 30, 2009 05:43 PM
