Anybody know where i can get wiring for swap CHEAP?
Old Nov 20, 2001 | 01:12 PM
KevronsEG's Avatar
Default Anybody know where i can get wiring for swap CHEAP?
i need the dual point to multi point an dthe vtec wires for b16 in std civic hatch.
Thanks GUYS
Old Nov 20, 2001 | 03:00 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: Anybody know where i can get wiring for swap CHEAP? (CIV616)
your B16 should come with those wires
I also went from DPFI to MPFI, you MUST use the
harness on your car right now, and then add the extra wires for the
other two injectors, plus the two wires for the distributor.
Once you are done with that, you need to add the four wires for
VTEC ECU.
All the wires you need come with the B16, if you got the
motor without the wires, let me know, I have a set of wires
and the injector resistor box which you will need as well.
Old Nov 20, 2001 | 07:30 PM
4G-CIVIC's Avatar
New User
Default Re: Anybody know where i can get wiring for swap CHEAP? (Spaceballs the lunch box)
Talk to BLOWN91HATCH (I probably messed up the name) but he sells the dx to sir conversion cheap.
You cant use the stock B16a harness cause its for a right hand drive car. So you need to convert your dx harness to multi-point plus add like 4 wires.
Old Nov 21, 2001 | 07:37 AM
Blown90hatcH's Avatar
Default Re: Anybody know where i can get wiring for swap CHEAP? (4G-CIVIC)
I can wire your car for you. DX to Sir for 100 + shipping. Let me know.
Turbo_EF@yahoo.com
Jason
JDMFreak
Sep 25, 2007 11:23 AM
90efcivic
Dec 7, 2005 04:19 AM
smash fascism
Apr 8, 2005 05:39 PM
90_Civic_Hatch
13
Jun 11, 2002 12:52 PM
