trippin temp gauge Question
Old Jul 6, 2004 | 04:07 PM
CRX+MaAN's Avatar
Default trippin temp gauge Question
Well my temp gauge will periodically jump to max hot, and then come back down to norm after 30sec for no apparent reason. I have a stong cooling system and know its not overheating.. So I went to a honda dealer and get a BRAND NEW temp gaugewire plug thing cause my old one had frayed wires, but this only helped some, as it still jumps up and down sometimes, even when its cold.
Anyone else have this problem?
thanx
Old Jul 6, 2004 | 04:30 PM
SETI20's Avatar
Default Re: trippin temp gauge Question (CRX+MaAN)
Probably air trapped in the system. I've had the same problem. Over time my upper radiator hose collapsed under vacuum pressure.
Old Jul 6, 2004 | 04:47 PM
CRX+MaAN's Avatar
Default Re: trippin temp gauge Question (SETI20)
If this is the case would you recomend just un-hooking a hose for a few hours to release some pressure or something? Thanks for the response
Old Jul 7, 2004 | 02:49 AM
CRX+MaAN's Avatar
Any advice would be helpful.. is my water pump going to die? (heard that somewhere, maybe)
Old Jul 7, 2004 | 05:07 AM
crx_88_si's Avatar
LMAO my car does this too, EXACT same symptoms.
Next time this happens smack the top of the cluster cover. that usually bumps mine back to normal, until i hit a bump on the road and boom up she goes again.
Old Jul 8, 2004 | 08:35 AM
crx_88_si's Avatar
Default Re: (crx_88_si)
bump, want resolution!!
Old Jul 8, 2004 | 08:50 AM
SETI20's Avatar
I simply screwed the cap off the radiator, and started the engine.
Cold engine ofcourse...you don't want boiling hot coolant flying all over the place.
There's probably a more fancy way to do this in tha manual...but this worked for me.
Old Jul 8, 2004 | 08:56 AM
crx_88_si's Avatar
no it's not a problem with the gauge. I mean It's normal and then it shoots right to hot, like, instant, not slowly or gradually, like a switch almost. as quick as a oil PSI gauge when you punch it in neutral from idle.
Old Jul 8, 2004 | 09:05 AM
SETI20's Avatar
That's because air gets hotter then coolant. So if a patch of hoi air hits the sensor...voila...temp shoots up.
Old Jul 8, 2004 | 09:06 AM
crx_88_si's Avatar
so when I smack the top of the cluster the air bubble comes out? jk w/ ya, but its not air for sure.
Old Jul 8, 2004 | 09:14 AM
SETI20's Avatar
Maybe it's cuz your car is coming apart?
That'll teach you smacking a rex!! :D
Old Jul 8, 2004 | 09:33 AM
crx_88_si's Avatar
Default Re: (SETI20)
I know that when the gauge gets a clean ground it spikes hot. I think the temp gauge in the cluster is toast. :/ anyone sellin a cheap 88-89 cluster?
Old Jul 8, 2004 | 09:37 AM
wtsexton's Avatar
Mine does that too!
Old Jul 8, 2004 | 09:40 AM
crx_88_si's Avatar
i think we've found a common problem w/ these cars.
Old Jul 8, 2004 | 10:39 AM
Slow89HB's Avatar
Mine does it too, but only after swapping in a crx si cluster. :/
Old Jul 8, 2004 | 10:45 AM
wtsexton's Avatar
All I know is that is the Gauge its self the wiring has been check and check.
Old Sep 23, 2005 | 07:56 AM
crx_88_si's Avatar
Default Re: (wtsexton)
back from the dead.
anyone have some thoughts.
Old Sep 23, 2005 | 10:15 AM
PINKS's Avatar
I want a CRX tattoed on my butt
just pray your not overheating haha
Old Sep 23, 2005 | 11:19 AM
crx_88_si's Avatar
lol funny you say that. my water pump failed on me the other friday and i had no clue.. by by pump, timing belt, tensioner, RAD.
o well. live and learn.
Old Sep 26, 2005 | 06:16 AM
crx_88_si's Avatar
up again, anyone have input?
Old Sep 26, 2005 | 07:04 AM
SiMateoAko's Avatar
Default Re: trippin temp gauge Question (crx_88_si)
If it is caused by air bubbles in your coolant line,, just be sure to bleed the system when you put new coolant in. Air bubbles will kill an engine faster than Vin Diesel.
Old Sep 26, 2005 | 07:34 AM
crx_88_si's Avatar
ok, it's DEFINATELY NOT air bubbles.
If i flick the cluster it will cause the guage to go to normal sometimes. so definately NOT a coolant problem.
Old Sep 26, 2005 | 07:40 AM
ghost_ryder35's Avatar
i think you should try just installing a new cluster like you said before. if it fixes the problem then you know you were right
Old Sep 26, 2005 | 08:24 AM
kranked91dx's Avatar
Default Re: (ghost_ryder35)
EVERY TIME you put new coolant or water or water wetter into your cooling system, let it run for a few minute, then use the bleeder on the front water neck to remoove water.
Follow Helm manual for further information.
EF cooling system tend to keep air into circulation, so bleed a couple time.
hope this help
kranked.
cpingor
Honda Civic (2001 - 2005)
Jun 7, 2011 11:24 PM
lilo_goki
Mar 27, 2011 09:38 AM
projekt90ef
Jan 19, 2010 03:43 PM
Andrew Sutherland
Jun 29, 2008 08:55 AM
DIYZane
Oct 29, 2007 08:44 PM
