progress pics and some questions...
Old Jul 6, 2004 | 01:55 PM
HatchBox's Avatar
Skoobie no more...
Default progress pics and some questions...
First the Questions.
Ok on the fuel pump there is the positive wire which is rivited into the top, But the plastic peice that covers it cracked and broke, what can i used to seal it?
liquid electricall tape, sylicone ect...
here is a pic.
2, I have a custom exhaust
as seen here.
and i added a rear sway bar. but i think i might have clearance issues when i drop it down, like the sway bar will push up on the exhaust. opinions. ?
progress :
battery in the back *the right way* with 2 parallel lines running to the front.
thanks for looking at my crap box
Old Jul 6, 2004 | 02:04 PM
LAMA's Avatar
Default Re: progress pics and some questions... (Hybrid Hatchback)
looking good.
my idea on the exahust is to cut out a small section where the sway bar is and make a little bend in it.
but you wont know untill you drop it back down.
Old Jul 6, 2004 | 02:14 PM
RCautoworks's Avatar
Looks like it coming along, I suggest putting a piece of wood under the jack stands so that don't slide.
Old Jul 6, 2004 | 02:31 PM
HatchBox's Avatar
Skoobie no more...
Default Re: progress pics and some questions... (90blackcrx)
thanks for the relpies
anyone got a idea about that connecter on the fuel pump assembly ...i kinda wanna put it back in tonight.
Old Jul 6, 2004 | 02:37 PM
Use rtv sealant to seal it off.
HatchBox's Avatar
Skoobie no more...
stores such as autozone would carry this correct?
Old Jul 6, 2004 | 02:40 PM
EyelessCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Hatchback &raquo;</TD></TR><TR><TD CLASS="quote">stores such as autozone would carry this correct? </TD></TR></TABLE>
I believe so....
Old Jul 6, 2004 | 03:03 PM
HatchBox's Avatar
Skoobie no more...
Default Re: progress pics and some questions... (EyelessCRX)
thank you!
also anyone know what torque spec that bolt for the fuel line is??
Old Jul 6, 2004 | 03:47 PM
amy's Avatar
amy
it d be nice to see some pics of it when its on the ground!
looks good so far...... when will it be actually running?
Old Jul 6, 2004 | 04:07 PM
HatchBox's Avatar
Skoobie no more...
Default Re: progress pics and some questions... (amy del sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy del sol &raquo;</TD></TR><TR><TD CLASS="quote">it d be nice to see some pics of it when its on the ground!
looks good so far...... when will it be actually running?</TD></TR></TABLE>
i like that looki it has now jacked 5 feet in the air.
Who knows, soon hopefully but not intime for the Niagra meet
Old Jul 6, 2004 | 04:49 PM
goforbroke's Avatar
MEAT PATTY
I had a similar problem as you with the exhaust hiting the rear sway bar. I went to pep boys and got some exhaust wrap and wraped it around the sway bar. I didn't use the sealant in the kit. Its working pretty good so far. My exhaust was hitting my sway bar making a very irritating noise.
Old Jul 6, 2004 | 06:04 PM
strict 9 ef's Avatar
Default Re: progress pics and some questions... (goforbroke)
not sure but i don't think it's smart to run ur exhaust on that side because when the fuel line leaks it usually leaks right by the driver rear wheel and if gas gets on the exhaust i don't think u will like what will happen.
not sure i am just saying that honda ran the exhaust the opposite side from the fuel lines.
can anyone verify what i am saying is true?
Old Jul 6, 2004 | 06:42 PM
HatchBox's Avatar
Skoobie no more...
Default Re: progress pics and some questions... (strict 9 ef)
yeah i know that, it is just temperary until i can get a real exhaust.
Old Jul 6, 2004 | 07:08 PM
LAMA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strict 9 ef &raquo;</TD></TR><TR><TD CLASS="quote">can anyone verify what i am saying is true? </TD></TR></TABLE>
makes sence to me.
never thought of that.
justinwinn
Nov 25, 2010 04:31 PM
NeKe1point0
Aug 10, 2008 02:25 PM
hondacivic4g
Dec 19, 2003 04:21 PM
hondacivic4g
Dec 17, 2003 09:28 PM
rhettster
12
Feb 3, 2003 10:23 PM
