Planning multiple amps...max power draw in a Civic?
Old Jul 6, 2004 | 12:45 PM
TheKamikazeSquirrel's Avatar
Default Planning multiple amps...max power draw in a Civic?
I'm planning to add to the stereo in my Civic...it currently has 2 10's in the trunk, but I going to be building a custom box to house 4 10's and to run off of either two medium sized two channel amps with each sub getting its own channel, or one big two channel amp with two subs sharing a channel (It'll be in the 600-800watt range). My question is if any one knows what the max power draw is, in amperage, that can be placed on the '99-00 Civic LX electrical system without draining the battery? The car currently has an Optima Yellowtop battery, no caps. Thanx for your help guys. ---D.
Old Jul 6, 2004 | 05:33 PM
Jim Truett's Avatar
Default Re: Planning multiple amps...max power draw in a Civic? (TheKamikazeSquirrel)
You should have a 70 amp alternator. I have had a 1600 watt RMS (Phoenix Gold) system in my '02 (80 amp alternator) for more than a year now with no problems. I have spent the necessary $ on wiring the car properly though. You should be fine with 800 watts if you run 4 gauge wire to the amps, reinforce the ground wire from the battery to the chassis and I would recommend at least a 1 farad capacitor.
Old Jul 7, 2004 | 09:45 AM
MCall's Avatar
heh
all depends how high the rpms are
chillerice
Audio / Security / Video
12
Feb 9, 2013 07:32 PM
///Nick
Aug 13, 2011 04:06 PM
03djmAccrd
Jul 9, 2010 12:13 AM
vargas
Nov 29, 2007 05:58 PM
carloselpavo
11
Sep 26, 2007 06:46 PM
