HELP. CEL after swap
Old Jul 6, 2004 | 09:26 AM
fred92htch's Avatar
Default HELP. CEL after swap
Okay, we started with a 91 HF. Swapped in a 92 d15 from a DX hatch. No CEL'before the swap.
Basically just changed the block and IM / throttle body. Kept the HF dizzy and injectors.
Stated getting a CEL (one flash) for oxygen? We kept the same o2 sensor with one wire and it LOOKS fine. CEL comes on after a few minutes sometimes and other times it won't come on till after an hour of driving. When the light comes on the motor runs rough.
Could this be a faulty o2 sensor?
The one thing different about the IM is on the passeenger side there is some kind of sensor with a white three wire plug and a vacuum hose. We plugged the vacuum line and left the plug undone.
Anyone have an idea what we need here?
Thanks for the help.
Old Jul 6, 2004 | 09:43 AM
crx_88_si's Avatar
so you put a 92 d15 block and head but re-used the 91 hf IM/TB and Inj?
what ecu did u use?
Old Jul 6, 2004 | 12:34 PM
fred92htch's Avatar
Default Re: (crx_88_si)
No, we used the DX block and head, intake manifold and throttle body. We kept the HF ECU and distributor. We also kept the HF injectors because the connectors were different for each motor. I believe they flow the same though.
Old Jul 6, 2004 | 02:02 PM
LoSt is BlaCk's Avatar
Default Re: (fred92htch)
what what code is it throwing? cel 1?
Old Jul 6, 2004 | 07:08 PM
fred92htch's Avatar
Default Re: (LoStMyBoOsT)
Yes, CEL 1 (one flash)
Old Jul 6, 2004 | 10:24 PM
how is the fuel consumption?
Old Jul 7, 2004 | 04:56 AM
fred92htch's Avatar
Seems to be using more gas.
Old Jul 7, 2004 | 04:58 AM
crx_88_si's Avatar
HF engine harness?
Old Jul 7, 2004 | 05:53 AM
redfish's Avatar
Default Re: HELP. CEL after swap (fred92htch)
What happens when the check engine light comes on does the ecu try to fix the problem and make it run worse? anybody got a answer?
Old Jul 7, 2004 | 05:57 AM
redfish's Avatar
Yes to the HF engine harness
Old Jul 7, 2004 | 08:21 AM
fred92htch's Avatar
Default Re: (redfish)
Hi Brah,
The ECU does not try to fix the problem but goes into a "closed loop" default mode that stops constantly adjusting the air / fuel mixture. Instead it just stays at one setting.
By the way everyone, it is redfish's car. I was posting for him.
Old Jul 7, 2004 | 08:27 PM
fred92htch's Avatar
Bump...
No ideas?
Old Jul 8, 2004 | 11:20 AM
redfish's Avatar
Looks like no help bro. I am suffering with the small wave pattern. I will be putting the clutch in the green car this weekend and proably drive it to Ca. for the surf trip. Latter
Old Jul 8, 2004 | 01:30 PM
fred92htch's Avatar
yO! I put this in the tech forum. See if we can get an answer there.
godruler
Nov 17, 2005 05:12 PM
laterdaz
Mar 7, 2005 07:02 PM
fred92htch
Jul 13, 2004 02:00 PM
fred92htch
Aug 18, 2003 01:44 PM
REXvtecSI
Apr 3, 2002 04:37 PM
