My first Dyno...
Stock Type-R with V-AFC:
I specifically asked the tech to tune the bottom to mid-range.
I'm happy with it... since my near 170hp peaked at 7800 rpm.
[Modified by oryanh, 11:42 AM 11/20/2001]
[Modified by oryanh, 11:43 AM 11/20/2001]
[Modified by oryanh, 6:05 AM 11/21/2001]
Baaaa!
EDIT
Ok... there it is.
EDIT
Maybe not...
Any other Photopoint "like" free sites out there?
[Modified by oryanh, 11:40 AM 11/20/2001]
[Modified by oryanh, 11:41 AM 11/20/2001]
EDIT
Ok... there it is.
EDIT
Maybe not...
FYI.. by adding a 4-1 header w/ test pipe and milling my head 12 thousandths for 11:1 compression... I gained about 12 ft/lbs of torque solid.
I notice stock ITR's post weak torque numbers but niiice peak HP especially for a stock motor..
Does that spike at the end count as your peak power output. It looks like it's good for another 5 whp. Not a flame but that seems to be a dyno glitch.
I might be wrong.
Thanks,
CB
I might be wrong.
Thanks,
CB
The "Dyno glitch" you speak of was that everything past 7800 was omited.
The last few runs he leaned to achieve a higher peak, something like 173, however I was more concerned about low-mid range.
It's like a ham sandwich... How much ham would you like on your sandwich?
Just compare it to the distance between the two plots.
The left side is a wee bit meatier than the right side, but meaty none the less.
