Honda S2000 Honda S2000
Does powersteering draws away power?
Old Jul 6, 2004 | 07:27 AM
soundzero's Avatar
Default Does powersteering draws HP away?
Well, my car was dropped off at the dealership for them check my steering system.
Last two days, I was driving without the powersteering and I will have to say, I felt more power from the car. is it my imagination? or does powersteering system draws HP away?
Old Jul 6, 2004 | 09:53 AM
steven975's Avatar
Default Re: Does powersteering draws HP away? (soundzero)
Most of it is your "wish" for more power.
Yes, the PS pump presents some resistance, and any motor would make more power without it. You'll probably notice it more in the lower end.
Old Jul 6, 2004 | 11:23 AM
Blue-Civic-Hybrid's Avatar
Loved
No, the S2000 uses an electric power steering system which does not draw any power from the motor.
You will not feel an power increase... for further proof, go to http://www.s2ki.com
Old Jul 8, 2004 | 01:50 AM
Muz's Avatar
Muz
Electrically Powered Steering System
In place of a conventional hydraulic system, with its hoses, fluid and power drain, the S2000 uses an electrically assisted power steering system. At low speeds, more power-steering assist is provided, which eases maneuvering and parking. As vehicle speed increases, less power assist is supplied, giving the steering a more direct feel.
Source:
http://www.hondanews.com/CatID...e=asc
Old Jul 8, 2004 | 01:38 PM
evil vapor's Avatar
Default Re: Does powersteering draws HP away? (Blue-Civic-Hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue-Civic-Hybrid &raquo;</TD></TR><TR><TD CLASS="quote">No, the S2000 uses an electric power steering system which does not draw any power from the motor.
By drawing more current from the electrical system, there is a loss encountered through greater resistence spinning the altenator. However, the losses are far less than running a mechanical pump that hampers high rpm output.
fastboy559
44
Feb 3, 2010 12:54 PM
Dan
Honda Fit
Oct 29, 2008 12:49 PM
digital sol
Dec 31, 2005 04:06 AM
