Automatic Antenna Replacement - 1995 Accord EX 4 Door
I have a 1995 Accord EX 4 Door. My automatic (telescoping) antenna was stuck in the up position and then broke off. I can still here the motor running when I turn the radio on/off. What's the best (and cheapest) fix? Is there a cheap fixed (non-telescoping) mast that I can use for replacement? I have see some motor and mast assemblies for sale but I'm not sure if I can do the install (I'm no expert machanic). How do I access the assembly through the trunk without "breaking" the plastic liner? Any help and/or advice would be appreciated.
brouss@flash.net
brouss@flash.net
Where the hell is the antenna? I got a 96 EX and can't find the darn thing...and yes I turned on the radio first.
if you don't have a hole on the passenger side of the rear quarter panel, your antenna is in the window looks kinda like a rear window defroster wire
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schmitey »</TD></TR><TR><TD CLASS="quote">Where the hell is the antenna? I got a 96 EX and can't find the darn thing...and yes I turned on the radio first.</TD></TR></TABLE>
The 96-97 Accords have the antenna built into the rear windshield.
AL_94AccordEX
Jan 8, 2008 01:24 PM
loonysalmon
Aug 18, 2007 10:50 AM
