Rear Disk Brakers on a DX 4 Door, What E Brake Cable do u need??
I just installed a Rear Disk Brakes from a 01 LS on my 00 Honda Civic 4 Door DX, use to have drums, ewww, we just cut the cable for now, becuase the Dx connect to the drums and don't uncrew, but what E Brake Lines would I need and would fit in the car
I was thinking 00 Si but would it reach
or 94-01 4 door LS E Brake Cable?
what one would work, let me know
thanks
I also installed all of this shitzzz
Omni Power IS TIGHT!!
thanks
You can use the e-brake cables from a 94-01 integra or 92-95 2/4dr civic (the ones that came with rear-discs). Don't use the Del Sols if anyone tries to sell you on that.
just a note,
i've read in alot of posts that the omnipower rear camber kit,
those bolts are the wrong length, and will be effed up if you install em.
u need the proper bolts.
the washers are koo tho... yay!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge »</TD></TR><TR><TD CLASS="quote">ya i didn't use the rear shim kit, i got the real deal, i got the Rear adjustable camber link and i used the oem screws same stuff</TD></TR></TABLE>
i went to the salvage yard today and i found out 99-00 si's work and also 94-01 teggy WON"T work, they are the NOT SAME SIZE, will work for any 96-00 doing rear disk brakes
thanks for the help tho
ALL 96-00 Civic, USE 99-00 SI, 2 door 3 door or 4 DOOR
GET 99-00 SI CABLES!
make sure u get a left and right, it will say L or R on the bracket
Modified by Quad-Damge at 11:29 PM 2/10/2005
philosofy1
May 31, 2007 04:07 PM
