Brake Swap Regarding E-Brake Cable.
i know it may sound like a noob question (and yes i searched). someone correct me if i'm wrong but, i need to swap the e-brake cable when going from drum to disc, correct?
i am using a integra rear disc set up, do i really need the integra e-brake cable, or can i go with one from a 00 civic si? or one from a 94-95 civic ex w/ rear disc brakes?
reason i ask is the acura dealer near me takes 2 weeks just to get the part in, unlike the honda dealer that takes 3 days.
Re: Brake Swap Regarding E-Brake Cable. (philosofy1)
You can use any rear disc brake cables from 92-00 civics/integras. Just don't use del sol ebrake cables cause they are different.
Re: Brake Swap Regarding E-Brake Cable. (delslo93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslo93 »</TD></TR><TR><TD CLASS="quote">You can use any rear disc brake cables from 92-00 civics/integras. Just don't use del sol ebrake cables cause they are different.</TD></TR></TABLE>
++2 you beet me to it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 »</TD></TR><TR><TD CLASS="quote">
++2 you beet me to it</TD></TR></TABLE>
sweet! thanks guys, i appreciate it!
Re: Brake Swap Regarding E-Brake Cable. (hybridmath)
i know for a fact that the integra hatch cables aree a little off on the secondary bracket it, but you can just drill and tap a new hole or you can just leave it un hooked
btw integra hatch - civic coupe 93
off by half an inch but works
Re: Brake Swap Regarding E-Brake Cable. (Team RS2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmath »</TD></TR><TR><TD CLASS="quote">what is the car you are putting this into
hatch coupe 4 door ??????
it's going on a hatchback.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 »</TD></TR><TR><TD CLASS="quote">i know for a fact that the integra hatch cables aree a little off on the secondary bracket it, but you can just drill and tap a new hole or you can just leave it un hooked
off by half an inch but works </TD></TR></TABLE>
thanks for the info!
turboblack2door
04-30-2009 03:18 PM
tekstyle
12-10-2007 01:40 AM
**DOHC HaTcH**
03-21-2007 12:48 PM
