4dr spoilers/seats options
Does anyone know if a 88-91 Prelude or 90 -93 Accord rear spoiler will fit on a 4dr? Or has anybody tried any other models spoilers?
And what seats from other models will fit in an 88 4dr?
THX
THX
u can make almost any generations seat fit in our EF sedans
just need to change the rail/silder under the seat and u set
as for the spoiler never tried it as I like my 4dr without one
if u like I got a double decker wing I found on the freeway
LoL
LoL
He's talking about the blackwidow-ish or mini "whale tail" that kinda uhm...like the Mugen CRX wing....imma try to find a pic
Something like this:
But with the ones on the accord/prelude have a notch for the H emblem. A dude in West Los Angeles has one on his 4th gen accord sedan. I forgot the color but he always makes a left onto Barrington Blvd (northbound) off National Blvd eastbound. Usually around 9am-ish.
Modified by MestizoRacer310 at 12:10 AM 7/6/2004
I've seen a sedan with an Accord tail on it. It fit pretty well. I'm not sure what exacty year the wing was from, but I am sure it was from an Accord that was built before 1994.
If you have the auto seatbelts then your choices are limited on seats unless you dont use the belt retrractors. I'm using DA Integra seats - they also have the retractors. Some creativity is involved to make them fit. You can either bend the rails or make some custom brackets.
I am looking for a oem spoiler look, I dont want a huge race wing. I was looking at the Accords spoilers becuz they have a nice long 3rd led brake light. I just hope it fits, I have been looking at the 90-93 ones.
i have 90 civic Si seats in my sedan, and the stock sedan rails (with seat belt thingy) bolted right up to the bottom of the Si seats. slick as cat ****.
and regarding your spoiler lip ideas, how about an 84-87 Prelude Si one? they were made of that rubbery material, same as the 1g CRX Si ones... so i'd think they'd be pretty easy to 'modify' to fit
search for pics of an 80s VW Jetta Carat. the little rear lip/spoiler looks like it'd fit the lines of the 4g sedan well. just another thought i guess.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">If you have the auto seatbelts then your choices are limited on seats unless you dont use the belt retrractors. I'm using DA Integra seats - they also have the retractors. Some creativity is involved to make them fit. You can either bend the rails or make some custom brackets.
Here is what I did:
Swap the outer rail on the seats. Put the stock Civic outer rail on the Integra seat. You have to enlarge one hole to make the bolt line up right along the side of the rail. Then fit the cover back over it.
Next, fit the seat in the car and redrill the front inner rail hole (the one towards the front of the cabin, near your feet)....it's only slightly off, so you may be able to just enlarge the hole and use a good washer.
For the rear inner rail, use a 1/4" spacer, get a longer bolt, and then drill the hole and you're done.
One thing you want to make sure of is to use the Integra auto seat belt assembly, as the stock Civic ones do not bolt onto the Integra seat.
EDIT: Just noticed that he said 88 Sedan.
Pick up some Si seats bro. You've got it easy
Here is what I did:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88fgfd »</TD></TR><TR><TD CLASS="quote">maybe u should look at the 90-93 4dr integra rear spoiler .. thats what i have on my 4 door and it looks pretty nice if u like a clean look</TD></TR></TABLE>
Got a pic?? Also on a side note....are the 90-93 integra sedans bigger than the civic sedan?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 »</TD></TR><TR><TD CLASS="quote">
yes they is bro......</TD></TR></TABLE>
Now what about the DA coupe...bigger?
I don't like it, but its your car. Maybe its just the view. Take a pic from an angle. If you like it, thats all that matters. LOL.
Also, are 88/89 4door tails interchangable with the 90/91 4door tails?? If so, invest in some 90/91 tails. They just make the 4d look SO much nicer.
I agree that the 90/91 style tails are better looking.
In reference to the wing: I like it! It looks like it fits perfect...a side view and an angled view would cement my feelings about it, though.
importboi22
23
Jun 15, 2004 01:34 PM
