HELP : 99-00 y8 mani w/ ls throttle body onto JDM D15B
Im using....
99-00 y8 Intake Manifold (i already got the extra holes screwed in and covered)
y8 gasket
Integra LS Throttle Body (using gasket maker instead of the ls gasket hope its ok
z6 IACV
z6 FTIV
my problem : THERE ARE no leaks, no hissing, no cels coming from my motor...all it does it idle between 1,500-2,500 CONSTANTLY!
I tried : replacing my FTIV are still no sign of luck...cleaned it, screwed it back in...still revs like ****. I also tried putting back on my stock z6 throttle body and still the same problem occurs. Im thinking its the z6 IACV...because my friend and I are using the same setup on our motors EXCEPT he has the y8 IACV on his.
I dont know whats wrong help me! IM DYING!
y8 gasket
)z6 IACV
z6 FTIV
the 99-00 y8 intake manis have 4 small holes above each runner/portit needs to be sealed up i used jb welb just have to make sure it is smooth on the side that bolts to the head
I will find you a pic of what i mean hold on
I'm in the process of doing the same thing...the EXACT same thing. I, as well, had the same problem. Didn't really pinpoint what the exact problem was, I just killed as many birds with one stone as I could...here goes. The first time I put it on, I used a 2000 mani gasket, z6 IACV, and the y8 tb gasket with the ls tb. When I got sick of the idle...I tried it again. Picked up a 96 mani gasket, used the y8 IACV, and got the ls tb gasket, and adjusted the idle screw...put it all on at once...problem solved. Hope this kind of helps ya man...you've been askin alot about this swap, tryin to get it right
BTW...you did jb weld the air induction ports, right?
.BTW...you did jb weld the air induction ports, right?
I have removed and installed more then 50 y8 mani swaps and never had a problem except the holes and it would idle high as ****
I have a y8 mani with ls tb on my 91 hatch with a d15b in it
but i used the complete mani so i wouldent no about the iacv
But If not that get a real tb gasket and try that
Modified by 1fst4 at 1:00 AM 7/6/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Uncle Ben »</TD></TR><TR><TD CLASS="quote">I'm in the process of doing the same thing...the EXACT same thing. I, as well, had the same problem. Didn't really pinpoint what the exact problem was, I just killed as many birds with one stone as I could...here goes. The first time I put it on, I used a 2000 mani gasket, z6 IACV, and the y8 tb gasket with the ls tb. When I got sick of the idle...I tried it again. Picked up a 96 mani gasket, used the y8 IACV, and got the ls tb gasket, and adjusted the idle screw...put it all on at once...problem solved. Hope this kind of helps ya man...you've been askin alot about this swap, tryin to get it right
.</TD></TR></TABLE>
wow thanks uncle ben...you do have about almost the same swap as i do. LOL im pretty sure its just the IACV that i have to change...because my friend has a y8 IACV and it works fine? hopefully it is! encourage me some more ben!
.</TD></TR></TABLE>wow thanks uncle ben...you do have about almost the same swap as i do. LOL im pretty sure its just the IACV that i have to change...because my friend has a y8 IACV and it works fine? hopefully it is! encourage me some more ben!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fst4 »</TD></TR><TR><TD CLASS="quote">the 99-00 y8 intake manis have 4 small holes above each runner/portit needs to be sealed up i used jb welb just have to make sure it is smooth on the side that bolts to the head
I will find you a pic of what i mean hold on</TD></TR></TABLE>
he already did i helped him with that already. someone help him
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fst4 »</TD></TR><TR><TD CLASS="quote">so when you say you have them screwed in?
Does that mean you used a screw?
Seriously man the only thing i can think of is to get it sealed up with like hondabond or jbweld
I have done more then 50 y8 mani swaps and never had a problem except the holes and it would idle high as ****
If not that get a real tb gasket and try that</TD></TR></TABLE>
i screwed in the ***** good enough i hear no whissles or anything leaks...screw + silicone sealant...im pretty sure i just have to use the y8 IACV
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 »</TD></TR><TR><TD CLASS="quote">
wow thanks uncle ben...you do have about almost the same swap as i do. LOL im pretty sure its just the IACV that i have to change...because my friend has a y8 IACV and it works fine? hopefully it is! encourage me some more ben! </TD></TR></TABLE>
Not a problem man, that's why we're here
. Just tryin to help a fellow SOHC soldier, we're a dying breed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 »</TD></TR><TR><TD CLASS="quote">PLEASE TELL ME ITS THE IACV!</TD></TR></TABLE>
Hmm, more than likely, but what tb/gasket is your friend using?
y8 gasket w/ gasket maker for the im and just "gasket maker" for the the tb. Im guessing it works fine because i hear no hissing or any leaks. Would it matter? Before i used the z6 tb gasket along with the ls tb and it leaked like a bitch...but now im guessing i fixed that problem with just gasket maker.
edit : my friend is using a y8 gasket...with his z6 tb gasket w/ a z6 tb. so about almost the same but different tbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 »</TD></TR><TR><TD CLASS="quote">has anybody ever used a z6 IACV with their y8 intake manifold that actually worked?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur »</TD></TR><TR><TD CLASS="quote"><--- Using z6 IACV on y8 manifold
They're the same thing ... cept the z6 is dirtier
OK im a bit closer to my goal...for some reason...HOW THE HELL are you using a z6 IACV on a y8 and its working! Well anywho took apart my IACV again...cleaned it and reinstalled it...but this time.....it idled fine for about 30 secs...on the ftiv untill it switched over to my z6 IACV and then it started to bounce...so the IACV has to be the problem! I can smell it!
1. the z6 does not mount onto the y8 without grinding the big metal bump.
1. i dont know even though if it looks the same it isnt working for me!
</TD></TR></TABLE>OK im a bit closer to my goal...for some reason...HOW THE HELL are you using a z6 IACV on a y8 and its working! Well anywho took apart my IACV again...cleaned it and reinstalled it...but this time.....it idled fine for about 30 secs...on the ftiv untill it switched over to my z6 IACV and then it started to bounce...so the IACV has to be the problem! I can smell it!
ben...the y8 iacv runs 2 coolant lines too right? one to the ftiv and the other to one of the ***** on the block...is that correct?
At one point, I thought my IACV was fugged up (2000 Y8). So, I personally went and pulled an IACV from a '95 EX. It wasnt the culprit, but it works fine now ... the z6 IACV is on there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur »</TD></TR><TR><TD CLASS="quote">At one point, I thought my IACV was fugged up (2000 Y8). So, I personally went and pulled an IACV from a '95 EX. It wasnt the culprit, but it works fine now ... the z6 IACV is on there.</TD></TR></TABLE>
wtf did you just plug and play? didnt you have to shave off that bump for your z6 iacv to fit? how did you do it?
