What Pistons for LS motor???
Old Nov 20, 2001 | 06:44 AM
civictom's Avatar
Default What Pistons for LS motor???
I just got in on those eagle rods and now I wanted to know what pistons I should use for my turbo LS motor... I was told that JE doesn't make pistons for it unless you get them custom and I could get SRP's but haven't heard anything good about them....I wanted to keep the compression stock...so which pistons are recommended by those with LS-turboed cars
b18bturbo's Avatar
Default Re: What Pistons for LS motor??? (civictom)
get the srp they hold good and i never had any issues with them.
Old Nov 20, 2001 | 06:50 AM
civictom's Avatar
Default Re: What Pistons for LS motor??? (b18bturbo)
What compression did you get/ or what compression do you recommend?
Old Nov 20, 2001 | 06:58 AM
newsense's Avatar
New User
i dont think they make pistons for **** tommy...
Old Nov 20, 2001 | 07:00 AM
rtype11's Avatar
if you can wait just ask JE to make you a set and copy the dimensional specs from the SRP's, just keep in mind that the JE alloy expands at a different rate.
for street go 9.0 for race only 8.5:1
Old Nov 20, 2001 | 07:01 AM
civictom's Avatar
Default Re: What Pistons for LS motor??? (newsense)
haha, that's messed up man...what kind of pistons are you going to get when you rebuild your motor?
Old Nov 20, 2001 | 11:08 AM
boosted3g's Avatar
If you need SRPs pistons I have a set I just took out of my motor today. They were used for aroud 6K miles and they seem to hold up well. I boosted 22psi with no problems. If your interested or need more info give me a shout at Boosted3gaol.com. First 100 bucks takes them
Old Nov 20, 2001 | 12:42 PM
millertime's Avatar
New User
Default Re: What Pistons for LS motor??? (boosted3g)
WQhats wrong with your pistons that you are selling for 100 bucks?
millertime's Avatar
New User
WQhats wrong with your pistons that you are selling for 100 bucks?whats the bore size too
Old Nov 20, 2001 | 12:48 PM
boosted3g's Avatar
Default Re: What Pistons for LS motor??? (millertime)
They are the standard 81mm size. I now have a 84.5mm bore so these are no use to me. Other than the fact that they are dirty and have a few small scratches on the sides they are fine. I will also include the wrist pins and spiral locks with them. Also they are 9.2:1 compresssion ratio.
Old Nov 20, 2001 | 07:47 PM
civictom's Avatar
Default Re: What Pistons for LS motor??? (97 JDM LS DC2)
So how much boost can the SRP pistons 9-2-1 handle ....I've heard that no more than 15lbs is recommended but then I've also heard as much as you want pretty much as long as its tuned properly..
wesley_925
Mar 31, 2008 08:44 AM
Khmerican
Jun 6, 2007 09:35 AM
jdm.ej
May 9, 2005 03:19 PM
GusRock77
Honda S2000
16
Mar 1, 2005 12:24 PM
sshaikh01
Nov 11, 2002 01:50 PM
