JDM b16a swap to 94 sol - distributor?
Old Jul 5, 2004 | 02:26 PM
nomotorsol's Avatar
Default JDM b16a swap to 94 sol - distributor?
yeah, so swapping 1st gen b16a into a 94 Del Sol that had the D16Z6 in it. I'm using the Del Sol wiring harness, so i am wanting to use the D16 ''dizzy'' on the B16. Is this possible, or am i just retarded. The only problem with the B16 is that the plugs on it are massive, compared to the ones of the D16. There are the same amount of wires on both. Could I just cut and solder the wires from the D16 onto the B16? Any help would be great, since this is the last part of our swap....we need help.
Old Jul 6, 2004 | 09:38 AM
nomotorsol's Avatar
Default Re: JDM b16a swap to 94 sol - distributor? (RedRABBlT)
bump because i'm in desperate need of help
Old Jul 6, 2004 | 10:09 AM
speedfreek128's Avatar
you cant use a single cam dist on a B series without ghetto rigging it.....you could change the plugs to OBD1 so it will plug into your harness but i dont recommend that.....call Distributor King you can get a brand new dist for Honda-Tech price for about $185 shipped....thats where i got mine and its good quality
Old Jul 6, 2004 | 10:10 AM
Kendall's Avatar
You'll need an OBD-1 VTEC dizzy. Every once in a while, one pops up in the classifieds for a good price.
Old Jul 6, 2004 | 10:41 AM
Del Sol SiR's Avatar
make sure you get the dizzy for 94-95 Del Sol VTEC.
Old Jul 6, 2004 | 12:20 PM
nomotorsol's Avatar
Default Re: (DelSolSiR)
thank you very very much solved that problem....time to make a phone call to Distrib. King
(760)doogie
May 28, 2008 09:23 AM
reddg3214
Nov 14, 2005 06:28 AM
nomotorsol
Jun 18, 2004 09:19 AM
ReCar0s.rule
15
Aug 4, 2003 08:41 AM
